Old 08-Sep-2005, 15:32   #11
pibbow pibbow is offline
Mood: Very sad
They are brand new you cheeky sod.
Old 08-Sep-2005, 17:53   #12
mikesps mikesps is offline
If the head bearings are new, they may have seated properly now and need another small adjustment.
Swingarm pivot bearings and rear wheel bearings in good condition? Sometimes problems felt at one end of the bike are caused at the other end.
It may just be normal, quite a few bikes will start to shake at some speed while slowing down without the damping of a pair of hands on the bars.
Mike
Old 08-Sep-2005, 18:58   #13
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
My CBR1000 did it at 40mph change the tyre and wheel bearings made no difference. Got chating to a guy at a rally on one and he hadn't noticed untill we went out on the run together and tested it. His did the same thing. Seems to be some strange resinance thing going on.
Stearing damper even on the lowest setting fix it though.
Adam
Old 09-Sep-2005, 00:48   #14
weeveetwin's Avatar
This shouldn't happen on an 888. I can't even provoke it on mine - and I've never known anyone else complain of it either. Must be something amiss pibbow.
(My old Jota would 'shimmy' sometimes when slowing down. Never did find out what caused it. Fitted a damper eventually).
Old 09-Sep-2005, 03:33   #15
RightSaidFred RightSaidFred is offline
RightSaidFred's Avatar
Mood: I AM looking forward to racing..
Shazam should be along in a minute to explain.
Shazaaam? Shazaam! Where are yooouuuu!!
Old 10-Sep-2005, 00:53   #16
888heaven 888heaven is offline
Mood: UKGS'ers Non PC and Vibrant
steering weave
Hi pibbow
I've had the T8 for 2 1/2 years with rusted head bearings,new bearings worn tyres wrong pressures two up and never even had a slight waggle not even coming down from small wheelies.
not something to think of but its not been binded in a past life.
ian
ps
have you checked fork oil and that all adjustments are equal on both forks and when you reinserted the forks did you line it all up with the wheel spindle aligned and tight just a thought.
[Edited on 9-9-2005 by 888heaven]
Old 04-Nov-2005, 12:50   #17
Mood: Very sad
Still can't get to the bottom of this it is driving me nut's Please some one Help Me!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-Nov-2005, 13:02   #18
I had exactly this on my 999, same kind of speed also, from around 55 down to say 45 the front end shook it's head all over the place, was a real pain as I travel through a lot of 50 limits.
To be honest I just ignored it, but I did change a hell of a lot on the bike to get it set-up for me in the meantime, ride height, head angle, springs front and rear, but the problem still persisted until I recently replaced the tyres (F+R) and voila shake gone, I'd done less than 2000 miles on them also, just fried them on track.
Might be worth a shout, even if it doesn't fix the problem you'll still use the tyres.
Old 04-Nov-2005, 13:06   #19
Mood: Very sad
Thank's mate, 500 miles were on track day's and I did not get it before as the head races were stiff. I will get a set fitted asap and see how it is.
Old 04-Nov-2005, 13:07   #20
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
I'd still bet on front tyre, if you where closer you could throw my wheel in and see if that killed it dead. Anyone local to you with a good one?
[Edited on 4-11-2005 by Rob B]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:44.
