Old 08-Sep-2005, 23:37   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
748 Debaffled cans - Chip advice
my 748 has what i think are debaffled standard cans. the inside diameter of the end bores is 40mm (height) X 47mm (width). they are stamped ZDM14.
i think the standard chip is installed. will this be ok, or should i get an upgrade chip? i have some standard cans from my previous 2000 model 748E, which i can fit if necessary.
i'm considering getting some carbon termis. if i want to fit 50mm cans what other bits (ie:link pipes/chip) will i need.
sorry if this info is elsewhere on the site
[Edited on 8-9-2005 by zhed44]
Old 08-Sep-2005, 23:45   #2
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
If the standard cans have been cored, I reckon a chip for open 45mm pipes should do the job, same chip if you go to 45mm termis too.
You can always get a custom chip that matches the cans precisely - a Ultimap eprom. Sigma do these, info here;
http://www.sigmaperformance.com/services.htm
Tim
Old 08-Sep-2005, 23:46   #3
Rattler's Avatar
Just read that you might gor 50mm termis - the chip for open 50mm cans will do the job here - you can get these from JHP;
http://www.nxgn-ltd.com/ezweblite/pu...mance_list.asp
Tim
Old 09-Sep-2005, 01:15   #4
zhed44's Avatar
Mood: YELLOW!!!
thanks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:13.
