Old 31-Aug-2005, 22:01
Douglas Douglas is offline
Ducati/datatool alarm
Hello
I am trying to fit a Ducati (Datatool Evo plus) alarm to my 600ss. I think that is the alarm fitted by Ducati.
Does anyone have any instalation infortmation. I have identified how it plugs into the bike loom, but wonder about the various flying leads. I assume one plugs into each front indicator. What do the others plug into?
Any snipperts of info welcome!
Thanks
Douglas
Old 31-Aug-2005, 23:50
weeveetwin's Avatar
...and to each rear indicator! Also, one goes to the little flashing red warning light fitted 'tween the clocks.
(Mine's just thrown a 'wobbly' so I'll be delving deeper into its workings at the weekend).
Old 01-Sep-2005, 00:18
Any poiners as to which wires connect to the rear indicators and the LED?
Old 01-Sep-2005, 00:19
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
This is from my Veto Evo destructions from my ST2....
Left hand indicator & one alarm earth ( two wires 2.8mm spade terminals,1 purple tagged ) to the left hand indicator on the bike - the purple tagged one to the white/black wire on the bike, the alarm black wire to black on the bike.
Right hand indicator ( 2.8mm spade terminal, 1 purple tagged on its own ) to the right hand indicator on the bike - the purple tagged one to the white/green wire on the bike.
2 green tagged wires - programming / accessory loop
1 yellow/green tagged wire - accessory siren / pager.
If you need a copy of the instructions... drop me a line.
HTH
Andy
Alarm LED - identified by bullet connectors - connect to the led as appropriate.
Power wire - 6mm ring terminal - to positive terminal on battery.
[Edited on 31-8-2005 by Rushjob]
Old 01-Sep-2005, 00:21
Rushjob's Avatar
Mood: :-)
None go to the rear indicators on the ST - it doesn't matter anyway whether you hook in to the front or rear as the front & rear indicators are already connected in the bike wiring loom!
Old 17-Sep-2005, 11:30
Thanks for the help. Unfortunately I wasnt able to work it out with sufficient confidence to wire it up to the bike.
However I have just got a copy of the alarm fitting instructions from Datatool. So if they are successful, I will report back!
Old 01-Oct-2005, 07:28
Hullo. I have now successfully fitted the alarm, and it works fine. It was fairly straightforward. So if anyone needs a acopy of the instructions, please feel free to get in touch.
Regards
douglas
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:06.
