Old 31-Aug-2005, 22:52   #11
deej deej is offline
deej's Avatar
£25 each from jhp i beleive
Old 19-Sep-2005, 10:03   #12
748IOM 748IOM is offline
Mood: Yellow!!
Originally posted by rxtim
The air/fuel mixture is somewhat critical though, you don't want it too lean and going bang.
How can it go bang from the fuel/air mix being too lean? The fuel doesn't provide the lubrication to the engine like a 2 stroke would so surely if anything all that will happen is the engine will stall???
Old 19-Sep-2005, 13:07   #13
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Someone will probably explain it much better than me! I'm no engine expert but I do know that a very lean mixture leads to higher combustion chamber temperatures which can lead to piston etc damage. A melted or holed piston would cost a little more than getting the fueling sorted with the correct chip!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:14.
