Old 23-Sep-2005, 11:38   #1
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
996R Flywheel
Apparently the flywheel on the 916 weighs in at 2.6kg's. Seen a lightweight one at 0,7kg's. However does the 996R have a lightened one already fitted?
Old 23-Sep-2005, 11:43   #2
keefer keefer is offline
keefer's Avatar
some interesting reading
http://www.ducatisportingclub.com/xm...3470#pid227563
would imagine the R has a light one already ?
Old 23-Sep-2005, 12:01   #3
I doubt if the has that much lighter a flywheel as it is sold as a roda bike, where the momentum given by a heavier flywheel makes for a smoother engine at low speeds, also the alternator will no doubt be the same as a road one as it needs to supply enough current for the lights, where as a race bike only has to wory about the Injection/fuel/ignition side of things.
I am currnetly looking at replacements for my 955 Corse flywheel, which is stell but has no starting gear so I need to replace it with a alloy one with starting gear which should way the same, but still a fair saving over a SPS road setup.
Old 23-Sep-2005, 13:36   #4
smilo006's Avatar
Interesting. Seems that the whole 996 and 998 range have the same flywheel. Exceptions are the SPS and SPSIII and the 748R. In the new range the 749R has another flywheel. However all 999 models have the same.
Thought provoking article from Shazzam as usual. Thanks.
Old 23-Sep-2005, 22:02   #5
rcgbob44's Avatar
Wots a "roda" bike mister?
Old 23-Sep-2005, 22:45   #6
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
I'm reasonably sure that the standard 996R flywheel is not the lightweight jobbie
Tim
Old 24-Sep-2005, 03:00   #7
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Tim
I think you are absolutely sure tim. Seeing has I bought your lightweight off you
Old 27-Sep-2005, 11:43   #8
sps955 sps955 is offline
Bikes: 998R.
Mood: Onshore and happy.
Don't know about the 996R but my 998R did not have a lightweight flywheel fitted.Thing felt as though it was stainless steel.I couldn't believe the difference in weight when i changed mine.
Only real downside was the bike does not want to tickover when cold now.Everything else is a benefit.Well worth it in my book.
Old 27-Sep-2005, 12:41   #9
Rattler's Avatar
Tim
When you get to my age fella, you can't be certain about anything!!!
My doubt was whether I had the lightweight flywheel fitted to the R or the SPS (or both!!!!)
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:08.
