Old 26-Sep-2005, 03:42   #1
djb djb is offline
djb's Avatar
my first duke.
after 15 years got myself a 748 - woohoo! aint no going back now.
fitted termis this weekend - wooooooooohoooooooo!
two minor complaints though -
wrists hurt like hell by the time I get out my drive and squirrels like hell on banding / white lines - anyone got any solutions?
god, I'm in love.
D
Old 26-Sep-2005, 08:46   #2
m1keyp m1keyp is offline
Cycle cat bar risers for the wrists see the thread
Air gun for squirels
Old 26-Sep-2005, 11:39   #3
Harv748 Harv748 is offline
Harv748's Avatar
Yep...bar raisers for the wrists (do a search...several posts about the various options available)...and the squirelling is probably down to a worn rear tyre.
On a 748 you should be running a 180 section tyre, and once they are on their way out (squaring off) they do twich like buggery over the banding/white lines.
New tyre...sorted.
Old 26-Sep-2005, 12:08   #4
Martin Dower Martin Dower is offline
Bikes: 1098s Tric
Mood: Tricolore :)
Wrists could be a bike fitness thing, give it a while and you might get used to it. I struggled at first on my old 748 and adapted my hand position slightly over time and found I had no problems and even ended up doing a 700 miles blast from Dijon to Yorkshire only stopping for fuel and coffee and I had no wrist problems at all.
Tyres...bane of my life at the moment, ever since I upgraded to the 748R I have not got on at all well with the Dragons that are fitted. Must change them soon
Old 26-Sep-2005, 12:18   #5
Harv748's Avatar
Diablos mate...they're the future
Also, regarding the wrist ache...you can rotate the brake and clutch levers around and down a little to help alignment with your hand/fingers. This makes a big big difference when it comes to the comfort on the bike.
Remove the lever clamp from the clip-on, and you will see a small roll-pin which locates the lever in a standard position. Remove this pin, either by pulling it out if your lucky or grinding it off, and then you can put the clamp back on, and now rotate it to a position of your choice.
I my levers rotated down as far as they can go before they hit the indicators when turning!!! Works for me and feels a darn sight better than standard.
Old 26-Sep-2005, 12:30   #6
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
Great stuff, your wrists will get used to it, check age ot tyres, pressures etc, etc.. welcome to the fold.
Old 26-Sep-2005, 15:23   #7
748IOM 748IOM is offline
Mood: Yellow!!
748's have very low bars, but I wouldn't have it any other way.
You'll strengthen up over time.
Welcome and Enjoy
[Edited on 26-9-2005 by 748IOM]
Old 26-Sep-2005, 20:12   #8
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Welcome djb. Are you only 15?
And speaking of bars - as is the custom here I'll have a southern comfort thanks, no ice
Whereabouts are you hailing from?
Old 26-Sep-2005, 21:07   #9
You have beaten me to it, ditto to all that Harv748 has written
Chris.
Old 27-Sep-2005, 00:49   #10
glj100 glj100 is offline
I have a 998 and I am only 5'5". I have fitted Heli-Bars and they are a revalation. No wrist ache any more.
My 2 pennys worth!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:34.
