Old 18-Oct-2005, 23:56
ratchet's Avatar
ratchet ratchet is offline
Mood: bring on the sun !
got my 4s
got the 4s from manchester the other week now got another 1000 miles on the clock since collection. love the power and ride but need to try to get more preload for two up riding,( any ideas) can`t keep the wife off the back, she can last all day now after being used to the monster.
Old 19-Oct-2005, 00:00
GsxrAge's Avatar
GsxrAge GsxrAge is offline
Ohlins
Old 19-Oct-2005, 00:07
Originally posted by Dseered
I'll get my coat !
LMAO!!
It hurts at first but they get used to it in the end
[Edited on 18-10-2005 by TP]
Old 19-Oct-2005, 00:08
daryl daryl is offline
Hi
Welcome to the 4s club.
The rear preload on the 4s is easy to adjust using the knob by the side panel. Clockwise increases preload and anti clock decreases it. The standard setting is for a spring length of 150mm. Get yourself a six inch ruler (or metric if you must!) Two up with luggage I increase the preload so that spring length is 140mm.
After a bit of practice you get to know how many turns you need on the knob so when touring I don't need to carry a ruler. I usually set it back to standard when I get back home
HTH
Daryl
Old 19-Oct-2005, 00:59
Monty's Avatar
Originally posted by AGE996
Ohlins
Got that as standard on an ST4S!
John
Old 19-Oct-2005, 09:29
Derek's Avatar
Derek Derek is offline
Bikes: ST4s ABS
Ratchet, good to hear you've got the bike now and are having fun with it. as Darryl says preload adjustment is with the knob at the RH side. I don't know what you weigh but I'm around 190lbs .I adjusted the front preload for 40mm sag and the rear for 35mm which has the knob at 3 turns in. For 2-up I crank it up to 7 turns in. I found it useful to paint a thin white line on the knob - it makes counting the turns easier.
You should have come on the Trossachs run on Sunday. You would have had a great ride and a chance to meets some more of us and talk about Ducatis.
[Edited on 19-10-2005 by Derek]
Old 19-Oct-2005, 09:49
YMFB's Avatar
YMFB YMFB is offline
Welcome to the DSC ST4 section.
Sorry to marginally hi jack the thread but I would like an adjustable ohlins for my ST4 from an ST4S if anyone has one.
My wife also likes it on the back but hasnt got used to the jarring she gets when we hit even a fairly small bump.
Old 19-Oct-2005, 20:55
Athelstan's Avatar
Athelstan Athelstan is offline
Mood: Abbia Divertimento---o0o---Cassaforte Di Soggiomo
Welcome Ratchet - and anyone else with the astute common sense to get an ST4s
If you or anyone else from DSC are in my neck of the woods next season (it's getting very cold here and I'm desparately hoping to get one last ride in before the snow and police close the high passes at the end of the month) I'll be more than happy to offer tour route tips and a friendly greeting.
Now chaps / ladies - has anyone suffered the same problem: yesterday I noticed that the rear brake pipe line, where it passes through the simple "wire guide" was chaffing somewhat despite the "black armour" strip that encases the brake pipe at this point. If you have, how did you stop the chaffing?
Cheers.
Old 19-Oct-2005, 21:00
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
noticed mine on the st2 the other day and i rekon its nearly sall the way through
ministry of crap designs came up with that hanger i rekon
i'm planning on using it as a good excuse to upgrade to braided hoses
Old 19-Oct-2005, 21:26
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
Yep... mine has done that too.
Just rotated the black sleeving a bit.
Kept an eye on it & no probs in the last 12 months or so...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:47.
