Old 27-Oct-2005, 17:07   #41
guest1 guest1 is offline
Originally posted by Rally
Hey, I'm just trying to help out here!
Yes, the rear nut requires a 36mm socket. I think we've established that.
But there seems to be some doubt over the torque setting so I put up the pdf so people can look it up for themselves. It says 180 Nm (+-10%) (or 132 lbft if you're Rockhopper )
(scouse accent) Calm down, calm down.
I only know the socket size for sure cos I adjusted the chain last night.
As for the 180Nm, I personally employ a midget to come and hold the socket whilst I turn the bike.
Always been 180Nm from 03 to 06.
It also says in the manual that chain adjustment should be done by dealer.....OMG, Is my warranty void now?
Old 27-Oct-2005, 17:50   #42
Rally Rally is offline
Rally's Avatar
Is that a 1/2in midget or 3/8th?
Old 27-Oct-2005, 18:28   #43
Yep,you can lead a horse to water............!
Old 27-Oct-2005, 22:21   #44
duc daz duc daz is offline
duc daz's Avatar
Mood: a ducati is for life not just for christmas
its a 36mm socket for sure
Old 27-Oct-2005, 22:26   #45
chris999 chris999 is offline
Mood: red and proud !!!!
jesus -- this has turned into some thread..
not being funny but if you think M30 nut is the socket size (30mm) maybe someone more knowledgeable should be adjusting such a critical part of the bike ...
+ this has been covered before in this section (correctly the first time) - search !!!??
just a thought ??!!!!
Old 27-Oct-2005, 22:28   #46
mark749s mark749s is offline
mark749s's Avatar
if you measure a nut or bolt across flats this is the corresponding socket/spanner size. if you measure your back wheel nut you will find it is 36mm across flats
another piece of useless info
mark
Old 27-Oct-2005, 22:37   #47
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Can I just add that the tolerance on the given setting is +/- 5%, not 10.%....
Ducks, grabs coat & heads for cover
Old 27-Oct-2005, 23:06   #48
logyk logyk is offline
logyk's Avatar
Mood: Relaxed - don't worry about things you can't change
'Kin 'ell....trying to get you lot to agree anything is like getting unanimity in the HoC !
So its 180nm is it ?
Old 27-Oct-2005, 23:16   #49
Davieravie Davieravie is offline
Davieravie's Avatar
Mood: Warmed up and ready to go
Use the old method we used on aircraft....180 Nm is roughly three and a half white fingers or 4 if you are a girl....SIMPLE!!! :P
Old 28-Oct-2005, 10:52   #50
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:09.
