Old 11-Nov-2005, 10:40
GlennG GlennG is offline
Mood: accepting the inevitable
620 Sport Tank Info required
Any of the other 620 Sport owners ever drained their tanks?
Should the "drain" allen bolt have a washer on it?
(Mine doesn't but I would have expected a fibre or aluminium one to be there to help seal the joint between bolt and steel tank)
I ask as I'm trying to fix a very small leak that is coming from the rear of the tank somewhere.
The workshop manual I have shows two exploded diagrams of the petrol tank but no reference to this allen drain bolt.
Old 11-Nov-2005, 10:45
ali's Avatar
ali ali is offline
Mood: Damp
Don't know about the bolt, but I know that the leak is common. Tonio had it last year, it was under the plate which the hinge mounts to, and right bugger it was to fix. We ended up using lots of tank goo and it just about worked, but I wouldn't recommend it!
Good luck.
Ali
Old 11-Nov-2005, 11:02
Hi Ali
"Tonio had it last year, it was under the plate which the hinge mounts to, and right bugger it was to fix ... "
Tonio did mention the leak when I bought the bike, I was just hoping it might be something easy to fix ... looks like I need to investigate this plate some more then.
Glenn
Old 11-Nov-2005, 11:16
Tonio600's Avatar
Tonio600 Tonio600 is offline
Mood: What a wonderful world.
I took the tank to the welder who usually fixes the leaking SSie tanks coming from ProTwins. And I think they did a good job on it. What you can try is replacing the bolt I used by the real Ducati bolt as its shape is like the bolt and the washer are the same part...
Old 11-Nov-2005, 11:19
Tonio600's Avatar
Message original : dubelg
That's because the tank which is fitted on the 620 must come from a 750 or a 900 SSie. The standard 620 tank (the gray one) doesn't have a drain hole... That's why I used the first bolt I found.
Old 11-Nov-2005, 12:40
Hi Tonio,
Thanks for the info I'll try and order the right allen bolt for a 750/900 tank then, I didn't realise the other grey tank didn't have a drain bolt - not looked at the bottom of it yet oops!
Old 11-Nov-2005, 12:45
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
IF you need the tank with a leak repairing, I have a very good man who welds up old tanks for me.
U2U if interested
Old 11-Nov-2005, 13:02
Tonio600's Avatar
If your man is based in East Grinstead, the tank already went to his workshop
[Edité le 11-11-2005 par Tonio600]
Old 11-Nov-2005, 13:42
On my 916 tanks I have used a copper brake banjo washer to do the job, would probably have used a Dowty seal if I had had one about at the time, but the copper one did the job
Old 11-Nov-2005, 16:44
"would probably have used a Dowty seal ..."
Not heard of these before, what are they?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:58.
