Old 12-Nov-2005, 21:56
duc daz's Avatar
duc daz duc daz is offline
Mood: a ducati is for life not just for christmas
how easy is it
Textcan some give me a step by step on how to change a pressure plate springs and collars on my 999
Old 12-Nov-2005, 22:00
Dibble
here you go, read this thread, its the same for all 748/9** engines inc your 999, just ignore the bits about removing the plates, you donr need to do that to just change a pressure plate, just tap the pushrod out of the old pressure plae and insert into the new one ..... I take it you have bought an open cover to show off the pressure plat ??
http://217.199.188.40/xmb/viewthread...7882#pid161078
[Edited on 12-11-2005 by DIBBLE]
Old 12-Nov-2005, 22:02
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
Take off clutch cover.
Undo all 6 spring bolts doing this even number of turns each so they loosen at roughly the same rate.
Remove bolts, spring caps & springs.
You may need to use a small drift like an old jewellers screwdriver to punch the clutch pushrod out of the centre of the pressure plate.
Remove pressure plate.
When you come to put the new plate on, align the dot on the edge of the plate with the spring post which has a line through the end & ensure the pushrod is seated properly.
Insert new springs caps & bolts & tighten down evenly.
Enjoy.
It's dead easy... while it's out you may as well clean up the plats if you feel up to it... just don't breathe in the dust!!
Old 12-Nov-2005, 22:04
duc daz's Avatar
Old 12-Nov-2005, 22:07
duc daz's Avatar
cheers for that .my mate pedro 749r is going to show me the way i hope .just wanted to fill my head with a bit of info thanks again
Old 12-Nov-2005, 22:08
Dibble
ha ha ha .. we have all just mis read that, he only wants to hanges the springs .. lol, not the pressure plate or the plates .. ha ah a
ok here goes
Remove Clutch Cover
Undo springs in opposing pairs
remove springs
put new springs and collars back in
retighten in pairs
put cover back on ....
make a cup of tea and pat yourself on the back
Old 12-Nov-2005, 22:24
duc daz's Avatar
you lot are bonkers
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:11.
