Old 16-Nov-2005, 00:27   #1
Paul748bp Paul748bp is offline
Paul748bp's Avatar
PIPES 748 bp 45ml
hi there im thinking of getting some exhaust pipes for my 748 but like every buyer of them which is best for the bike noise isnt a issue just as long as it is not insanly loud, performance i would like to be better the bike has 17K on her and is going to be serviced in feb the bikes off the road at the moment so a nice long time for me to decide.
I have searched around and found many makes styles and PRICES ranging from the ebay 250 to ducati performance 1grand ones i have a budget of 500quid possibly 600 i have my eyes set on termis as that seems to be the pipe on everything ducati but i have been told to look at JHP racing ARROW and REMUS or are there any others that should be considered ???
When i make my mine up on the pipes i want is it better to change the chip? as i have been told buy my local ducati dealer (st neots motorcycles) that changing the chip is not needed really ? but if you all say it needs changing where and what do i get ??
hope to have some feedback asap
cheers
Paul.
Old 16-Nov-2005, 00:30   #2
sheeny748 sheeny748 is offline
ive got a ducati chip for45mm open pipes,yours for £25 posted. from experience yes you do need to change it.
Old 16-Nov-2005, 00:47   #3
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Termi's are great, for that money yoy'll pick some up easily, JHp are also great. You should realy change your chip though, they aren't that expensive.
Old 16-Nov-2005, 01:03   #4
phil_h phil_h is offline
phil_h's Avatar
If you run a race can with a std chip and you use the throttle properly,
it is possible that the mixture runs so weak it damages the piston.
Oh, and performance goes too Weak mixture = weak power
It probably isnt a good idea to use a dealer for servicing if they say you wont need to change the chip.
Old 16-Nov-2005, 01:10   #5
Scott as reservoir cogs has some 45mm carbon termis going for £195
https://www.reservoircogs.com/Produc...productID=2053
Old 16-Nov-2005, 02:04   #6
DAZ748S DAZ748S is offline
hi there Daryl from st neots ...your pipes , dont bye a brand new set from a shop mate , plentey around . i got a new set of termi 45 end cans off of here for £310 , as for the chip i ran mine for a bit on a standard chip . it ran hot and also flat spot at top end , got a open chip now shifts mate
Old 16-Nov-2005, 02:08   #7
daryl again , got a spare set of micron end cans , carbon needs replacing on one if it can be done , sure it can ..if your local e mail me on DTURNER33@aol.com c what we can do
Old 16-Nov-2005, 11:08   #8
barryj barryj is offline
I have 45mm open Termis on my 748 and a guy on here sorted me a Ducati chip matched to the exhaust for £15, the bike had a chip change when I bought it but I could not find out what spec the chip was so decided to err on the safe side.
The difference with the Duc chip is amazing, crisper, faster response, and also louder. My assumption now is that the original chip was incorrect for the exhaust set up.
Old 16-Nov-2005, 11:14   #9
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
I recently put 50mm Termis on my 916 and got a new e-prom from JHP, Fantastic sound and a little more performance.
Take your time when replacing the e-prom, I used a small e-prom tool, worked for me, make sure all the legs are in place and away you go.....
Old 16-Nov-2005, 14:18   #10
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
Hi mate, I've got a 748S, put a set of 45mm Termi's on, never changed the chip and she has run fine for the last 18 months. Not one stalling, no flat spots, doesn't run hot or cold, absolutely perfect. Sounds absolutely awesome, as confirmed by the Kent fuzz.
Ade.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:37.
