Old 21-Nov-2005, 10:59
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Originally posted by diehard
I'm a big git so that probs explains it! But still doesnt solve my porb of getting it set up right...
Yeah I'm around the 95-100kg mark myself.
I can't comment too much on your particular setup, but my 750ss hated the cold. I used to park it outside, but under a cover. Leave it for anymore than a week in winter and you had no chance of starting it. Even after 3 or 4 days of no riding it was a lottery as to whether it kicked over or not. *shrug* I just learned to roll start it quite a lot - warms you right up on cold winter mornings, although ice on the road can be a bit tricky.
Old 21-Nov-2005, 17:29
diehard diehard is offline
Mood: Don't trust women!
Erm... This is the bike running on idle (little choke):
Old 21-Nov-2005, 17:31
And a close up, I'm sure it ain't ment to be like that!
Old 21-Nov-2005, 19:16
Ok I have checked the fuel filter, and ran the bike and the bubbles were comming off the 'sack thing' like made (hope thats normal). And I also took the power commander off and tried to run the bike and it was slightly worse.
I then tried the commander and it was no better than before. I don't get it. When the bike idles the light stays on the first bar of the lean possition (as in pics) with no change.
So I'm stuck, when I pull the throttle back to fast it dies like lack of fuel, if I take it easy, it's ok until I get into top revs and it starts to die again. Any ideas? I need to fix this tonight for work tomorrow!
Old 21-Nov-2005, 19:45
can you not use the low button to richen up that idle setting looks far to weak to me
Old 21-Nov-2005, 19:46
I just sent you a U2U mate, sorry, didn't see your post. I press all sorts of buttons when the bike is running and not running and it doesn't do zip, but I still have the probs (slightly worse) without the PC?
[Edited on 21-11-2005 by diehard]
Old 21-Nov-2005, 19:49
http://www.powercommander.com/manuals/User_Manual_6.pdf
  #18
Old 21-Nov-2005, 19:55
You say you truied the PC website
But maybe this users map is worth a try
http://www.powercommander.com/usermap701.shtml
  #19
Old 21-Nov-2005, 20:01
Well I have just tried programming the power commander on the bike and nothing happend at all and I followed it to the letter. I wonder if it's fooked? Or maby it doesnt have a map on it at all... Can it loose it's memory with a low battery on the bike? Just waiting for my mate to bring me my cables n book round so I can plug it into me comp...
  #20
Old 21-Nov-2005, 21:07
Well I think me power commander is not working and even without it fitted the problem is exactly the same. Pull the throttle back too quick and it dies, even when idleing. I think I'm just gonna have to give it up and get it into a garage.
Some sujestions I have had are, throttle posistioning sensor, the coils and plugs. But I don't know, injection bikes are new to me, I want carbs back!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:40.
