Old 29-Nov-2005, 19:22   #1
Red-leader Red-leader is offline
Mood: wobbly !!!
Carb deicer details required please.
My 91 900ss has no deiceing to the carbs, however the ever resourceful MR AK has some bits and I am after a photo or details as to how it should all fit together.
Haynes manual only mentions it but has no information.
Thanks Kev.
Or a complete unit no longer required would be even better
Old 29-Nov-2005, 19:36   #2
monstermob 998's Avatar
ive got the details you want from the owners manual and from the original kit BUT i have the kit for the 600 (no oil cooler) i can get them photo copied and send them to you if its any help
Old 29-Nov-2005, 19:53   #3
If you have no luck, I've got a complete kit, still in the box for the 900. £150 to your door
Old 29-Nov-2005, 21:07   #4
Mood: wobbly !!!
Monstermob those details would be great please if its not to much trouble.
Nelly thanks for the offer, I will see how I get on with AKs bits and bobs for the mo.
Thanks Kev
Old 29-Nov-2005, 21:15   #5
no worries mate e-mail or u2u your post address and i'll get them in the post tomorrow morning
have you tried FST?
[Edited on 29-11-2005 by monstermob 998]
Old 29-Nov-2005, 22:21   #6
webbyc webbyc is offline
webbyc's Avatar
Mood: www.suzukisportingclub.com the only place to be
Is AL trying to get rid of his old lighters
Old 03-Dec-2005, 04:25   #7
edwyun edwyun is offline
I always heard that those carb heaters never really helped.
I mean, the engine has to be hot for the oil to be able to heat the carbs for easy starting. BUT, to get the engine hot enough, you have to have already started and run the bike.
IMHO, better solution is to properly jet the Mikunis or step up to the FCR's
Old 03-Dec-2005, 22:59   #8
Mood: wobbly !!!
Just looking at the options at the moment. I have the addertive for the petrol which I will be trying this weekend. Its only if I do another Europe trip, dont want to be caught out in France.
Your coments are very wellcome.
Thanks Kev
Old 04-Dec-2005, 00:01   #9
kev -my thoughts and ramblings - this is what i have found - the worst cases of carb icing occurs when the air is very humid and cold (when it is foggy) this is i believe is because it isnt the petrol that affects the carbs it is the cold air drawn thru the carbs that is the problem- when i ran an open airbox with k+n and stage two dyno jet, unless i was accellerating hard the bike was spitting and popping all the time--i replaced the open airbox with the standard cover and instantly made a difference also after a few miles i stopped lifted the tank and directed the trumpets on the airbox at about 45 degrees outwards so as to lose the direct "ram air" effect this improved things to the degree that i could tell the difference in the running of the engine- finally i replaced the k+n with the standard filter and what a difference that made hardly a miss and the engine picked up a lot smoother all this using the FST at 50:1-- so to cut a long story short i have reverted back to my stage1carbs and a std filter set up for the winter, the bike ran well today but it wasnt as cold as it has been recently-- i'm currently thinking of fitting the carb heaters(that have been sat on the shelf since last yr) to the stage two carbs just to see how much difference it makes- although i have found that the FST seems to be coping well and i can live with the problem as things are----thoughts that i have had, albeit pie in the sky and a bit wacky is to add an oil cooler to the top of the airbox to create some sort of warm air induction system- like they do on light aircraft to alleviate induction icing--also i have noticed that when the carbs are suffering from "icing" the float bowls are dripping with condensation i wondered if a couple of those wrist bands that tennis players use would help wrapped around the bowls????
dave
Old 06-Dec-2005, 00:46   #10
Mood: wobbly !!!
Dave I went out Sunday morning with 200ml of Silkolene addertive in a full tank, and guess what---------------------------------------------------------------------------------------------------------Yep thats right it iced up like a advert from Icelands !
To be fair it has all the bad points that you mentioned above, open box, KN filter large main jets etc.
Next time I will try more Silkolene and see if that does the trick ! Oh and another suggestion is higher grade fuel such as Opitmax or similar.
The call to uncle Al (AK) is looming fast.
I can ride it when its iced but its no fun what so ever.
Bloody roll on summer.
K
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:35.
