Race
MotoGP / WSB / BSB / Local racing.
*** WARNING*** May contain race results!!
Old 08-Dec-2005, 12:39
Chris Wood's Avatar
Skids,
I've got a contact for some 996rs stuff and mags, clutch's etc..
U2U if interested.
Cheers.
Old 08-Dec-2005, 21:19
Chris Cheers, I have sent you a U2U
Old 10-Dec-2005, 00:21
deej's Avatar
deej deej is offline
kev try rich at louigimoto hes always got a load of stuff in the shop you may be able to buy, as your probably aware he likes his racing ducatis
Old 10-Dec-2005, 00:38
Deej
I know Rich well after racing against him for a couple of years in Sound of Thunder. Rich aslo knows Simons bike as he occasionally got close enough to see the back of it.
I am seeing somebody tomorrow that is breaking down his 955 Corse, some of the bits on it were mine at one point and other bits came from Dallas so the guy is likely to sort us some good prices.
Dallas has already lined up the Corse carbon airbox & air tubes, along with the alloy tank, Mag yokes and STM slipper clutch. So i'm off around there with my shopping list tomorrow.
Old 13-Dec-2005, 21:54
Originally posted by skidlids
So with all the knowledge we have in this club your suggestions would be appreciated.
Kev
Maybe that should have been lack of knowledge
So back to the main man on this aka Felix
Was wondering what yoke offset you had on your bike to match the longer arm, also interested in the rear and front ride height settings you raced with.
Kev
Old 13-Dec-2005, 22:30
Felix Felix is offline
Kev, I'll have to dig out the settings log to tell you exactly, but IIRC I pretty much used the standard factory recommended settings. Going from memory for now, front sag was 22 mm, rear sag was 10 mm, yoke offset was between 26 and 28 mm depending on circuit (but mostly 28 mm). Steering damper was on a very low setting, maybe 4 clicks. Front and rear ride height I'll have to look up in my logs, which should be tomorrow.
Old 13-Dec-2005, 22:57
Cheers Felix, I'm meeting up with Simon towards the end of the week so I will pass the info onto him then, it will give him other settings to try once testing gets under way in the new year, I can't see his current settings being much use if he changes the swingarm and yokes so it will be good to have a starting point.
  #18
Old 08-Jan-2006, 21:48
quick update
The 748RS is currently in parts, with the frame getting a repaint, when it goes back togeter it will have a few updates in the way of.
Mag longer arm with mag hub and corse rocker
Alloy tank
Mag wheels
STM slipper clutch
Larger Corse air-ducts
Carbon airbox
and
4-pad callipers.
On the look out for a uprated clutch slave cylinder, Radial clutch master cylinder
Also after the longer DP footpeg and gear lever where the lever pivots on the boss of the footpeg.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:29.
