General Motorcycles only
  #21
Old 24-Dec-2005, 13:27
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I have a document that does that. I will try to find it. If I do, I'll scan it and upload.
  #22
Old 24-Dec-2005, 16:44
butch890 butch890 is offline
Mood: Enjoying Togdom !
Originally posted by NBs996
I had a doc describing how the system worked and what talked to what, but I'll be buggered if can find it! Where's frank??!!
I think the easiest solution would be to try'n get hold of an unused set of clocks.
Nick,would a set of clocks from a buke that hasnt been coded not be ok?
The ones we fitted to Daves bike were off just such a bike.
Butch
  #23
Old 03-Jan-2006, 13:19
Butch...I'd be interested in those clocks if you want shot of them for a price.
I've made some small progress on this - I've removed all the dc motors from the panel, all the mounts etc and have built a small loom extension & tested it ok. The next step is to re-house the pcb in a suitable enclose from Maplins or RS. Once that is working I will be able to relocate it under the seat out of harm's way so, at least the bike can be used.
The next step after that is to obtain a cct diagram to try to find whether or not the panel can be jumpered out of the circuit.
I also plan to test it on the new 800 to verify whether or not panels can be interchanged between the bikes.
  #24
Old 03-Jan-2006, 15:37
Today I fitted the panel from the old bike to my new bike. It was immobilised and would not start. I fitted the new bike's panel to the old bike with the same results.
So.....it would seem that indeed you cannot swap panels and therefore you cannot use a 2nd-hand instrument panel that has been coded to another bike.
  #25
Old 03-Jan-2006, 18:47
The clocks we used were secondhand but had never been used with the red key,therefore uncoded.
If we had one such set in the paddock surely that would get us out of trouble.
Butch
  #26
Old 03-Jan-2006, 18:51
Alas I am not one of the DD crew but, that's a really good a noble idea. Well worth doing imo. Good on yer.
  #27
Old 03-Jan-2006, 21:53
phil_h's Avatar
phil_h phil_h is offline
So, anyone know the best person at Ducati UK we should contact to find out if there is a 'factory-approved' solution if one of us gets immobilised at a race meeting ?
(ie at the track - NOT paying a fortune to a dealer by plugging into their diagnostic equipment at their premises some considerable time after the racing finishes)
  #28
Old 03-Jan-2006, 21:55
phil_h's Avatar
Hmmm, even knowing how to tell if the clocks have ever been used with a red key would be a start, wouldnt it
  #29
Old 03-Jan-2006, 22:04
Phil...I've been through all this mate - with Ducat UK's technical rep'...can't remember his name now but, there isn't a workaround. It's a crazy daft situation.
  #30
Old 04-Jan-2006, 06:54
I will try to source a set of uncoded clocks as spares for all riders.
would only be "on loan " untill the end of the meeting and would need to be replaced if damaged-would that be ok for all riders?
butch
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:23.
