Old 07-Jan-2006, 00:45   #1
paologray paologray is offline
Mood: GETTING RIGHT OFF!!!
She refused to start...
evening all!
took the duke into work today for a wee ride. Decided to nip home for a spot of lunch at about 2pm, the bladdy thing wouldnt start!
Now, I know that the battery is quite low, as it has been progressively slowing the starter (as its getting colder). suppose my question is, do you need to have a good battery on the ducatis? I know the answer will be "YES!!", but please just tell me off, and tell me to stop being tight and buy a battery....
Old 07-Jan-2006, 01:08   #2
Yes u do need a good battery - stop being tight...get an optmiser and start there. Too many short trips with lights on etc in winter ain good of course.
Also - I think there was a hint your bike was well over due a service?
Suggesting that the oil is probably past its best etc.
Getting a multimeter and checking the battery voltage and charging could be good ideas as well, sadly!
Frank
Old 07-Jan-2006, 01:30   #3
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Its all about how much "Ooomph" you have crossing the cells that will give the power to turn over a Duke its not about Volts. As the battery gets old it looses the power to transfer that Ooomph. Flustrating as it is, a new battery is the only answer , about £40 for a good one . 4D
Old 07-Jan-2006, 01:44   #4
Fordie, I like your analagies!
It did start after about 30 seconds of jumping from a car battery, but seemed a bit, well, ****.
Moving into a new house next week with integral garage, so all the work you have been pestering me to do will be done (Frank-you know...)!!!
Another thing, is it typical for the 750 to be utterly un-rideable below 3000 revs?
Old 07-Jan-2006, 01:49   #5
I'd get your charging system checked out first before forking out on a new battery. If it isn't charging, the new battery will go the same way.
Old 07-Jan-2006, 01:53   #6
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Funny I got a 996 like that in the garage
Hope to get some more AA duracell tomorrow
Old 07-Jan-2006, 02:18   #7
Fordie's Avatar
Nelly, very true, as you no after refitting my fly wheel on the 996 It sounds a lot quieter too OOooooppps 4D
Old 07-Jan-2006, 04:44   #8
Early 750SS's are easy eough to bump start, I know as thats how I was starting mine the other week due to it having a flat battery (Bl**dy alarms)
Alarm now junked, checked charging all Ok dispite the light on the dash, which is probably on because the new style japanese regulator/rectifier fitted to it doesn't cater for it.
Old 07-Jan-2006, 11:45   #9
Herb Herb is offline
I had to bump start mine a couple of months back and it nearly killed me. I bought an optimiser after that and have had no problems since.
Old 08-Jan-2006, 09:40   #10
More good advice from Nelly.
Something else to consider is the fuel filter,when was it last replaced?Sounds ridiculous,but a partually blocked fuel filter can put a big strain on the electrics.I speak from experiance!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:51.
