Old 08-Jan-2006, 21:19   #21
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Bring it over here mate when it's dry and we can have a play.
I did also et mine to standard settings taken from the Haynes book then adjusted to suit me from there.
Old 08-Jan-2006, 23:58   #22
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
I have my bike set up with the steep head angle. I would say that I like it. But then my bike is set up with a high arse end but standard height front forks. I dont mind my bike getting a bit flappy when the going gets tough. It sure steers quick at warp drive.
When I sit on my mates 916 it feels like a chopper compared to mine but hey, each to their own.
I think that I will try the slower standard head angle again though as mine tends to feel a bit tucky when cornering on really slow bends. I quite fancey having my steering lock back as well.
Roll on the spring eh?
DC.
Old 24-Sep-2006, 17:20   #23
david.hicks's Avatar
When I bought my 996SPS it handled like a complete pig. The whole thing felt very vague, the back would wallow through corners if there were any bumps at all, and the front would tuck-in on slow corners.
On investigation I found that it was set-up as follows:
Front Showa:
Spring pre-load: 20mm (as standard)
Rebound damping: 12 clicks anti-clockwise (2 softer than standard)
Compression damping: 10 clicks anti-clockwise (2 harder than standard)
Rear Ohlins:
Spring pre-load: 151mm (as standard)
Rebound damping: 14 clicks anti-clockwise (as standard)
Compression damping: 17 clicks anti-clockwise (3 softer than standard)
Ride height tie-rod: (261mm as standard)
I took it back to standard and it was so much better! So far I have left it there. I need to ride the bike a lot more before I begin to think about changing it, but I'd welcome any suggestions for improvements from any suspension experts out there. I weigh 14.5 stone without my leathers. I ride solely on the road - a typical mixture of motorways, A's and bumpy B's. I guess I would describe my riding ability as average.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:50.
