Old 12-Sep-2003, 23:57
Yellow Bip Yellow Bip is offline
Mood: tired!!!!!!!!!
Spring Rating?
what spring rating is a ohlins rear 1091-16/64 289?
and how easy is it to change rear spring?
Old 13-Sep-2003, 00:28
Ohlin's spring code 1091-16/64 289 means:
1091 = length code
16 = Ohlins code for spring rate
64 = 6.4 kg/mm spring stiffness = 358 lb/in
289 = production batch number,
Old 13-Sep-2003, 00:33
Cheers Shazaam, so i suppose that is a bip spring or the same as a bip spring.
I am 5ft 4inches tall and weigh 10stone 5, so have been told i could run a 5.5 kg spring stiffness rate is this true?
Old 13-Sep-2003, 16:13
6.4Kg/mm is a mono spring the Bip spring is around a Kilo per mm heavier at 7.5Kg/mm
Old 13-Sep-2003, 21:06
Cheers Kev, that one will do then is it difficult to change spring?
Old 13-Sep-2003, 23:33
real easy on the ohlins, just back the collars right off, allow the spring to drop and then remove the colette. Before changing springs its best to check all your sag figures, if your body weight fails to obtain the desired amount of sag then a cahnge of spring would be a good idea.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:57.
