Old 13-Sep-2003, 20:08
psychlist's Avatar
Mood: Lucky? For some, maybe!
Lights!?!
My main beam is actually hitting the ground slightly before dipped!!!!!!!!!!
Is there absolutely NO adjustment on the individual casings?
Old 13-Sep-2003, 20:49
Nigel C's Avatar
Nigel C Nigel C is offline
Mood: happy bike passed MOT
Welcome to the world of crap 748 9** headlights Paul might as well hang a candle on the front of mine it'd do a better job they are only good for one thing being seen
haven't got my haynes comic to hand so i couldn't tell you !:P
Old 13-Sep-2003, 21:10
Yellow Bip Yellow Bip is offline
Mood: tired!!!!!!!!!
Paul the only root i have taken is changing bulbs to blue zenon which are 30% brighter, but as you now i cant see in the dark so i cant tell you if it is any good but one friend says it is, so for a measily £12 it might be worth a try.
Old 13-Sep-2003, 22:10
psychlist's Avatar
I\'m going back to Ducati over this.
No way is that a roadworthy setup
Like I said, main beam only illuminates the same bit of road already covered by dipped. I think that the construction and use requirements state that if main is set horizontal then dipped must fall a set distance in front of the vehicle.
I'll let you know what Ducati say!
Old 13-Sep-2003, 22:48
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
Paul, they are only like that on the Yellow ones, as they don't go fast enough to need a high beam. If you really need one, you will have to order a replacement from Ducati UK. Part number veryfastred998mainbeamunit
Old 13-Sep-2003, 23:44
As if my headlight wasn't bad enough before with the Yellow body kit on, after fitting the original red bodywork it was only fit for a reverse light.
Actually my red bike is far superior/faster at night but then TL1000S headlights are really good (well when the front wheels on the ground that is)
Old 15-Sep-2003, 15:49
Nigel C's Avatar
Quote:"Paul, they are only like that on the Yellow ones, as they don't go fast enough to need a high beam. If you really need one, you will have to order a replacement from Ducati UK. Part number veryfastred998mainbeamunit "
Your just jealous roy cos you haven't got a yellow one
Old 15-Sep-2003, 15:55
dickieducati's Avatar
you sure you're not riding it upside down ????
Old 15-Sep-2003, 17:24
BigJohn999 BigJohn999 is offline
You need the Aussie light unit. I got one for my 748 from ProTwins spring last year. Paired dip and main beams. Like taking a floodlight with you - not too much focus, just light everywhere
Old 15-Sep-2003, 18:11
NickH NickH is offline
Mood: Ambivalent
BJ999, Excuse my ignorance, what is the Aussie light unit and how much does it cost?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:01.
