Old 19-Jan-2006, 20:49   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Cutting lower panels
I know this has to be done carefully and slowly with a dremel.....BUT.....
...how or where do you mark to cut, is it a staight line or is it slightly curved.
dave
Old 19-Jan-2006, 21:10   #2
doogalman's Avatar
I've done it , BUT i had a pair of remnants of when someone else had done it. It was a case of measure and mark it and cut them carefully as required ( hacksaw blade as opposed to dremell, You can be more carefull by using a blade). I may have the offcuts that you could use as a template. I will check tomorrow. Some say don't do it , but it's your choice. I was happy doing it.
Old 19-Jan-2006, 21:21   #3
dave996's Avatar
Mood: Fed up...
Cheers Doogalman, that would be a great help.
dave
Old 19-Jan-2006, 21:30   #4
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
A cheaper alternative without buggering up the OEM panels is to buy cheap fibreglass panels. I have some from Vimori and I have to say that the colour impregnated F/glass looks as good as original. Plus, they are not expensive (about £40 or so a panel).
Old 19-Jan-2006, 21:31   #5
Stealth's Avatar
..... and I forgot to say they come pre cut for a bellypan
Old 19-Jan-2006, 21:50   #6
dave996's Avatar
Mood: Fed up...
I was let down on a pre cut right hand side today so I think I will go ahead and cut mine, besides one of my panels is buggered anyway so I thought what the hey I might as well cut these.
Old 21-Jan-2006, 16:45   #7
doogalman's Avatar
dave you have u2u
Old 21-Jan-2006, 18:42   #8
Pete A Pete A is offline
Pete A's Avatar
I cut my panels using a jigsaw with a fine blade in it - you need to cut the bottom out of the panel, close to the corner, all the way round. Then using something like a dremel tool with a mounted point (small grinding wheel) or similar burr, cut the panel back removing the turned under edge, making the panel flat. If you do it carefully the panel will end up with a radiused edge, and when fitted you won't even see any of the white showing.
As in my other post re. fitting a belly pan, the awkward bit is opening up the front return on the panels where they mate with the belly pan, which is designed to fit with the thinner carbon panels.
Hope this helps.
Old 21-Jan-2006, 19:33   #9
dave - I have an enclosed lower fairing 1 piece panel which would fit straight on - could do a deal for your std lowers????
Old 23-Jan-2006, 11:42   #10
dave996's Avatar
Mood: Fed up...
Cheers for the offer mate but I'm going to fit my dp carbon bellypan, besides my lower left is damaged it jumped off my garage roof!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:58.
