Old 24-Jan-2006, 11:33   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Ventura luggage & Termis
Having problems fitting the L-Brackets to the 996 (bip) with the termis in place. Basically the termis are to long and the L-bracket wont bolt to the rear footrest hole as it hits the termi.
The whole exhaust looks like it needs moving back about 1/2" for the bracket to fit, then none of the holes will line up on the balance pipe.
Any ideas
Old 24-Jan-2006, 11:51   #2
BDG BDG is offline
BDG's Avatar
Excuse me if i'm ststing the obvious, but there are fifferent kits for mono and bip subframes.
Have you got the right one? did you buy it new or secondhand?
Mine kit is for a mono so can't directly help but may help if can post a pic.
Also remember Fordie (i think) posting pics of his fittings on the site some time ago so it may be worth doing a search.
Old 24-Jan-2006, 12:30   #3
brand new kit was there when order was placed, Got part nunber d013-b for the l-brackets with the pack rack. Says that on the packaging.
Had a look at that pic looks the same as the one i got.
Will put up pic later tonight, after fitting std pipes to make sure that the parts do fit, as the termi are off at the mo.
Old 24-Jan-2006, 13:18   #4
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Its a few years since I fit mine to a 996s bip, I cant fully remember but is there not some washers included to shim the L bracket outwards away from the cans? Are the brackets touching the cans at both sides? I sold mine (to Dibble I think?) ages ago so I dont think I still have the instructions but I will have a peep in the garage.
Old 24-Jan-2006, 13:21   #5
BDG BDG is offline
BDG's Avatar
d013/b is the right part number for a 996 bip
Has the subframe been changed for a mono subframe, if not i'm at a complete loss.
Old 24-Jan-2006, 14:23   #6
m1keyp m1keyp is offline
My Arrow cans are longer and I hade to make a small bracket to make them fit.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:40.
