Old 24-Jan-2006, 22:18
zhed44's Avatar
zhed44 zhed44 is offline
Mood: YELLOW!!!
748. misfire on tickover. advice needed please
hi -
after riding for about 20 minutes the 748 started to go on and off one cylinder with much popping and banging every time i was stationary at lights etc. it was fine on the move though.
any ideas?
Old 24-Jan-2006, 22:22
madmav's Avatar
madmav madmav is offline
Bikes: 1098
Mood: Chilled
possible TPS
or just leaning off a little too much
or
crank angle sensor
or Air Leak on exhaust
popit in for a set up!
nelly?
bring it on !
Old 24-Jan-2006, 22:27
zhed44's Avatar
Mood: YELLOW!!!
Originally posted by madmav
possible TPS
sorry to be thick, but what is TPS?
[i]or just leaning off a little too much
LOL. i wasn't leaning off at all.
seriously though - i did wash the bike the day before, so i'm wondering if it might be water ingress somewhere
Old 24-Jan-2006, 22:28
deej's Avatar
deej deej is offline
spark plugs, sound similair to a problem i had when running my 853 in
Old 24-Jan-2006, 22:29
weeksy2 weeksy2 is offline
TPS, throttle position sensor.
madmav's Avatar
Bikes: 1098
Mood: Chilled
zhed
Throttle position sensor
but to be fair it could be somthing as simple as the porcelain crcked or even a dirty spark plug! just check the obvious stuff first
mav
Old 24-Jan-2006, 22:30
TPS equals throttle position sensor (about £130 for a new one). It tells the ecu how far open the throttle is.
I would have thought a problem with it would have affected both cylinders though.
An air leak or exhaust leak would be my first guess. Loose or dodgy spark plug perhaps?
Old 24-Jan-2006, 22:32
madmav's Avatar
Bikes: 1098
Mood: Chilled
[quote]Originally posted by zhed44
[i]
sounds mor like the problem
remove the plug caps and blow out with air!
they wont always dry out with heat as the water turns to condensation and causes the plugs to track out!!
Old 24-Jan-2006, 22:33
Does the rev counter bounce around?
Old 24-Jan-2006, 22:34
madmav's Avatar
Bikes: 1098
Mood: Chilled
Pmsl! we all know you'rs dont pass 4 thousand rpm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:44.
