Old 28-Jan-2006, 22:40   #1
900SL Pete 900SL Pete is offline
900SL Pete's Avatar
No Go
Bought the 748 some 3 weeks ago, been out a couple of times but not run it for 2 weeks.
I've come to start it today and no go. Its as if the battery is flat. So Ive charged it up for a couple of hours, the engine doesn't even turn over. There's just a whiring noise on the left side, and the fuel pump is running ok.
Do I need a new battery or is it something else
Anyone who can shed some light.
Old 28-Jan-2006, 23:07   #2
Dibble
right hand side of the bike near the starter solenoid is a white conector, its a pile of pooh, go ensure its clean and well connected, .. that may sort it .. its a known issue .. you'll find it jut in front / above the battery somewhere ...
Good luck
Old 29-Jan-2006, 17:16   #3
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
Does the bike have an alarm?
Old 29-Jan-2006, 21:56   #4
keefer keefer is offline
keefer's Avatar
sprag clutch
Old 29-Jan-2006, 22:38   #5
900SL Pete's Avatar
Forgive me for being stupid, but what is a sprag clutch
I've managed to dtart the bike with jump leads so I spose this confirms its the battery!
So I'll nave to spend some money in the next few days.
Thanks for the advice Guy's
Old 30-Jan-2006, 21:20   #6
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
I believe it is the bit of the starter that comes out to engage on crank to start it then springs back once bike starts if it goes it doesnt engage i think
Old 30-Jan-2006, 21:25   #7
keefer's Avatar
if you have started it with jump leads it unlikely its the sprag.
but your description was of a noise coming from down the left side. (starter motor) but the engine not turning over.
if the starter motor is turning then so must the motor unless the sprag clutch is not griping.
so any way you running good luck
Old 30-Jan-2006, 21:28   #8
Could be the solenoid I think, big circular think behind the heatsink etc, I ended up having to put a cable tie round mine as it kept vibrating lose every now and again
Old 30-Jan-2006, 21:43   #9
Did you jump it via the battery connections or directly to the starter motor? If you connected to the battery then it's doubtful the solenoid or the connector Dibble speaks of is the problem.
The sprag clutch is a "one way" bearing. When the starter spins up it turns a gear on the back of the flywheel that has the sprag mounted in it. The sprag grips the flywheel and turns the motor over. Once the starter is disengaged and the engine is running the sprag just sits there.
Your sprag clutch could be on the way out. The extra boost from the jumper battery could be enough to spin the starter motor faster and cause the sprag to grip harder and hence start the engine. It works like a centrifugal clutch............
It's not easy to check as the LHS engine cover needs to come off. Try a new battery. It may be enough to spin the starter fast enough to engage, but it may well give up in the future.
I don't have a reason for it, but especially on hi compression motors, the sprag sometimes plays up on cold engines. Once warmed through and for a few days after they work fine. Leave them for a while and they misbehave. Proabably down to thickened oil??
Old 30-Jan-2006, 21:50   #10
keefer's Avatar
you can hear them chime as they grip briefly then let go.
nicely put though Nelly
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:54.
