Old 30-Jan-2006, 18:28
Guido's Avatar
Be bluddy carefull with the swingarm bolt Steve.
It will need a fair bit of persuasion (9 out of 10 Dukes prefer to be tight barstewards). It might seem ok to use a 'drift' to hammer like buggery on the bolt but you can 'flare' the threaded end of the bolt (errrrmmm...like I did Doh!!! ) which makes it impossible to get back in or get the locking nut on once it is back in.
Go steady and be patient. It can take an age to get free. From now on I'll be removing mine each winter to polish and grease it up so's removal isn't such a chore.
Gc
Old 30-Jan-2006, 18:57
Carbon749's Avatar
Mood: I own a flame thrower
Took mine out of the 996. Pushed out with no problem at all ... guess i was one of the lucky ones.
One suggestion would be to try and take it out before taking everything off. Would be a pain to have the bike stripped and carfully balanced to then find you need to start hammering the swing arm pivot.
[Edited on 3-2-2006 by Carbon749]
Old 30-Jan-2006, 20:02
Mr C Mr C is offline
Originally posted by keefer
I guarantee your swing arm bolt will be stuck.
otherwise a quick job. good luck
I'd forgoten all about that episode!!
Old 30-Jan-2006, 20:42
keefer's Avatar
keefer keefer is offline
i will never forget
Old 30-Jan-2006, 21:52
weeksy2 weeksy2 is offline
LOL talk about putting me off a job lads.... Jeeeeesus
Old 30-Jan-2006, 21:58
keefer's Avatar
I think the best thing to do is as Dave said
try and remove it before anything else.
if that works job job'd
Old 30-Jan-2006, 22:13
sounds like a plan
fitting a new shock with Crust on Sunday, so will have it all in bits anyhow
cheers gents.
  #18
Old 30-Jan-2006, 22:19
Easier with one of these..............
  #19
Old 31-Jan-2006, 10:39
fil2's Avatar
fil2 fil2 is offline
Mood: is it still wet
U can tell thats yours its never been used...........:P
  #20
Old 03-Feb-2006, 11:26
I only made it the other day..................
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:46.
