Old 01-Feb-2006, 00:24   #1
Paul748bp Paul748bp is offline
Paul748bp's Avatar
exhaust springs
i just got some race cans and i have fitted them now in the process of putting them all done but stuck with the springs on the pipes behind the peg?????
i got one on the left pipe but the shorter right pipe is a right bitch any black art onto getting the spring on other wise im guna have to buy some stupidly long mole grips i think
Old 01-Feb-2006, 00:28   #2
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
I used a flat blade screwdriver under the hook and pull it out once it's hooked on the pipe. it also helps if you do the shorter one before you actually fit the the left hand pipe
Old 01-Feb-2006, 02:11   #3
Draper do a little cranked, hooked tool designed for the job. Priceless and it's only about a fiver.
Old 01-Feb-2006, 09:53   #4
weeksy2 weeksy2 is offline
there's a cracking trick for doing this..
Sadly i don't know it and used luck and a pair of long nosed pliers
Old 01-Feb-2006, 10:15   #5
Nick 916 Nick 916 is offline
Spring puller... saves a lot of time, priceless bit of kit,
Old 01-Feb-2006, 10:52   #6
m1keyp m1keyp is offline
http://www.monkeybike.co.uk/acatalog/Spring_Puller.html
Seems a good price to me!
Old 01-Feb-2006, 10:53   #7
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Make yourself a spring-puller from a wire coat hanger.
Takes about 1.5 seconds to make one.
I actually use 2 hooked together for that awkward one behind the pipe.
Spin
Old 01-Feb-2006, 10:53   #8
even better
http://cgi.ebay.co.uk/SPRING-PULLER-...QQcmdZViewItem
Old 01-Feb-2006, 15:06   #9
doogalman's Avatar
Or a loop of string with a screwdriver to pull on.
Old 01-Feb-2006, 15:10   #10
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mole grips - Schmole grips. Loop of electricall cable wrapped round hands does the trick and it's free. Well almost!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:32.
