Old 10-Feb-2006, 13:17   #11
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
... original CORSA !!! looks like ...
Sorry, the keyboard isn't friendly today ...
Old 10-Feb-2006, 15:12   #12
jgriff jgriff is offline
jgriff's Avatar
Mood: anamorphic with overtones of sanguineness!
Yep well the one I have is pretty much like that but in 3 pieces, with the rear section being oil seperator box with a line from the crank case breather going to it. Some tricky use of silastic will be needed. And I need spacers which are being made up, between the throttle body and bottom of air box. Nothing is ever easy when straying from the norm. It has been suggested that the air pressure sensor be relocated to behind the nose cone, but I'm not to sure about that. I would assume that local air pressure is more relavent than ambient air pressure.
Old 10-Feb-2006, 23:14   #13
phil911's Avatar
Can you send a pic of yours ???
Here's my original 94 ...
Old 11-Feb-2006, 05:07   #14
jgriff's Avatar
Here it is just sitting there after the first fit/look
Old 11-Feb-2006, 06:18   #15
jgriff's Avatar
Phill, Sever not playing today. i sent email.
Old 11-Feb-2006, 17:41   #16
851neil 851neil is offline
Mood: need a bike...
I've got a one piece Corse 94' carbon airbox and also the 3 piece carbon Corse used up to 93'.
The carbon 1 piece air tubes (X piece) are also Corse 94'.
I'll be selling the 3 piece carbon airbox as I've settled with using the 1 piece unit + frame mod.
The 3 piece box was used from 91' to 93' so would suit any 851 / 888 or 926 and has the benefit of the frame fail not needing to be modified.
I'm trying to resize my pictures and when I manage I'll post pics.
cheers
Neil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:50.
