Old 21-Sep-2003, 18:08
Joe McG Joe McG is offline
Vibration
Does anyone else experience severe vibration though the bars @ 5-6,000 RPM. After a few miles today, the bike was virtually unrideable. The bar ends seem quite substantial already, might be worth trying something heavier?
Apart from that, the usual niggles already mentioned on the board, and the fact that I have to cover another 300 miles to run-in, I love the bike even more than the 996 I part-exed.
Old 21-Sep-2003, 20:43
There's a couple of things you can do.
Try foam grips ($5 grips from a bicycle shop work very well). You can lessen vibration by isolating yourself and/or the bars from the vibration source by positioning a cushion (low frequency spring) along the path of vibration (foam between your hands and the bars) and/or use something to isolate the bars (i.e. rubber mounts) from the rest of the bike at high frequencies. You can also try riding gloves with thicker leather or gel padding on the palms.
Add weight to the handlebars - at the ends - LOTS of it. The handlebar is actually responding to the engine's vibrations and will vibrate in harmony (resonate) at certain engine RPM. You can change the resonant frequency of the handlebars so that the bars do not respond to the engine vibration at say cruising speeds (shorter stiffer bars will tend to cause the high amplitude vibration to shift to higher speeds, longer or weighted bars will tend to cause high amplitude vibration to shift to lower speeds). Some manufacturers include weighted bar-ends as part of the design.
Weighted bar-ends are added mass that will lower the resonant frequency of the bar so it vibrates less strongly but does not eliminate all vibration. In many cases, that's enough. You simply change the resonance to a frequency that the bike rarely generates or to a RPM that has less effect on the nerves in your hand. Shifting the resonant frequency is intended to reduce the strength (amplitude) of the vibration at your normal cruising RPM.
I went to a dive shop and paid $3.00 for a 3 lb. lead belt weight (wheel balance weights and lead fishing weights mixed with epoxy would work too), cut it up, hammered it into shape and shoved/wedged it in the handlebar. It’s got to be in there tight to work, closer to the free-end works best. The lead piece in each of my handle bars is about 5 in X 1/2 in.
Those lighter dinky bar-ends and Barsnake things they sell in bike shops aren't going to help as much. Placing rubber caulk inside the handlebars as some have suggested is unlikely to have much of an effect (beyond added mass) in damping vibration.
Old 21-Sep-2003, 20:57
Nope,no 'orrible vibes from mine.
I did 300 miles to Popham and back today with no aches or pains.
Mind you,I have ditched the standard h/bar grips.I could'nt get on with them and swapped them for the thick rubber ones found on the 748/996 etc.
Old 22-Sep-2003, 09:31
luckywhiteheather luckywhiteheather is offline
Mood: Electrically challenged
Nor mine!
Old 02-Oct-2003, 17:26
superlight3's Avatar
superlight3 superlight3 is offline
Mood: Anything but 'Yellow-Bellied'..!
We haven't got a Multistrada, but we do have a Monster 1000 DS, which essenally shares the same engine.
We found that with the standard cans the bike would have a severe vibration at around 4K revs, worse on the overrun coming down to a roundabout etc.
This has been totally cured by just fitting a pair of open silencers. Totally amazing. The transformation in the engine is like nothing we've experienced before with 'opening-up' a Ducati.
Cheers.
Lee.
http://www.monstershop-ducati.co.uk
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:17.
