Old 16-Feb-2006, 19:44   #1
aka.eric aka.eric is offline
Fixing clip
Does anybody have a pic of the fixing that holds these in place?Take it its a "rawplug" type that the screw goes into.
Old 16-Feb-2006, 19:49   #2
Errr...Can't quite see what you mean, but it looks like you need some wellnuts
Old 16-Feb-2006, 20:23   #3
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Is that bit off the fairing? Looking at the hole size I would say that Jools is right.You may need the same fixings as the ones which hold your side panels on.
Old 16-Feb-2006, 20:26   #4
The parts manual shows them as:-85040151A Insert
Wellnuts are shown as 036499020 M6
800063150 M5
Are you using wellnuts?if they work they will do for me.
Old 16-Feb-2006, 20:31   #5
philthy's Avatar
Still not sure where that bit goes. Go on ...give us a clue
Old 16-Feb-2006, 20:46   #6
Part no 23.
Old 16-Feb-2006, 20:52   #7
Try it a bit smaller!
Old 16-Feb-2006, 22:41   #8
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Mine has a small spring steel clip that slides over both edges of the panel. The 4mm fixing screw threds into that. Look at the fixings up on the headlight frame that hold the RH side panel, same I think. NLA from ducati though but Halfords do Odd Packs that have a very similar item. Do you want a pic?
Rgds, Rob
Old 16-Feb-2006, 22:45   #9
Please,a pic is always handy.
Old 16-Feb-2006, 22:58   #10
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Some T.8 1994 had red parts with a couple of nuts included in the plastic ...
Here's the black 1993 ...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:44.
