Old 20-Feb-2006, 11:38   #1
paologray paologray is offline
Mood: GETTING RIGHT OFF!!!
Popping into neutral...
does anyone else have trouble getting their 750ss into neutral at a standstill? I dont think ive ever been able to do it, only when coasting...
Old 20-Feb-2006, 11:58   #2
Herb Herb is offline
It can be a bit of a pain on my 750, but will go in with care. Normally I pop it into neutral just before I anticipate coming to a complete halt.
Hows the bike running now?
Old 20-Feb-2006, 12:09   #3
Check that your clutch is bled through properly, the slightest bit of air or water vapour and the clutch can drag giving you that effect. Also make sure that your chain is adjusted right, I've never quite been able to work out why but if it's not you can also find it difficult to get into neutral.
Old 20-Feb-2006, 12:09   #4
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
From experence with Ducati wet clutchs, even though you are getting full lift on the lever, it does not mean that the plates fully free off. This is worse if you do a lot of short journeys, as not enough oil get into teh clutch to keep the plates free
Old 20-Feb-2006, 12:22   #5
chicken chicken is offline
chicken's Avatar
they all do that sir
Old 20-Feb-2006, 12:51   #6
yeah, its not really a problem cos I very rarely stop anyway...!
The bike is running great now, think that optimate really makes a massive difference, keeping that battery topped up etc.
Ive had a thought, I used to (bad habit I know) stop the bike in gear by letting out the clutch lever instead of turning the ignition off. Do you think that would have caused some bad running/plug fouling/poor starting etc...
I dont do it now and shes running like a dream!
Plenty fast-but I still need to try and sort that slipping clutch problem.....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:59.
