Old 28-Feb-2006, 19:53   #1
beek beek is offline
caliper goldpaint
After a bit of hunting i found a reasonable match
It is actually called Brass.
wilkinsons £2.19 Brass ( B33 ) made by Plasti-Kote
see the picture shows my caliper before paint, after paint, and a clutch m/c to compare.
http://homepage.ntlworld.com/beekuk/.../brakes/rc.jpg
Old 28-Feb-2006, 23:36   #2
rob holmes rob holmes is offline
Looks a good match that beek, on the subject of paint what is the best paint to use to touch up the spring part of rear shock and also parts of engine casing? The paint to the shock spring looks like enamel type to me.
Old 01-Mar-2006, 17:11   #3
doogalman's Avatar
Its the engine paint that i want. I won't pull the motor out untill i get a good recomendation.
Old 02-Mar-2006, 12:04   #4
moor-ph0 moor-ph0 is offline
Hi,
Try RS Motorbike paints. There paints can withstand temperatures upto 200centigrade. I have a monster 1000 and sent then a piece of flaked off grey engine paint and they matched the colour. With weathering etc there are a variations of greys on the engine but the ready to use (RTU)with air brush paint I received is an excellent match. Ideally you should also purchase the two part primer which is an acid etch and the two part lacquer for finishing. The matt lacquer is better as it can handle higher temperatures than satin or gloss.
Geoff
Old 02-Mar-2006, 22:55   #5
doogalman's Avatar
Thanks Geoff. will give them a call at some point this year.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:40.
