Old 02-Mar-2006, 17:10   #1
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Gearbox fault?
I was out on the Multi the other Sunday and seem to have a problem when changing down from 5th to 4th. What would happen is when trying to get 4th it would instead get neutral. I would knock it back into 5th and try again and it would do the same. This happened a few times and I eventually realised that if I went from 6th to 5th then to 4th it was ok? But the problem only happened if when going up to box I never reached 6th and then started to change down. Anyone had similar faults?
Am wondering if it was just me and that I had not ridden for a few months, also my gear lever is slightly bent so maybe it could be that at fault?
My warranty is finished in a week so am going to book it in to be looked at.
Old 03-Mar-2006, 07:14   #2
Hmm,Ducati 'boxes are usually pretty good.How did the lever get bent?Over enthusiastic cornering,or dropped it?May have caused some internal damage,if the latter.
My 999bip used to miss the odd downshift,untill I found the linkage needed adjusting.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:00.
