Old 11-Mar-2006, 16:04   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
pressure plate not spinning
Pressure plate not spinning when the lever is pulled in (disengage clutch). it stops spinning after a short time.
Is my clutch on the way out or is it something not to worry about because i've not ever noticed it happen before.
Old 11-Mar-2006, 16:22   #2
stu 748 stu 748 is offline
stu 748's Avatar
Surely thats supposed to happen isnt it, thats what happens when you disengage the clutch by pulling the leaver in.
Old 11-Mar-2006, 16:23   #3
Smacks to me of some sort of leak internal or external on your fluid system.
I would suggest if theres no fluid leaking on the floor, it may be an internal leak where master cylinder or more probably slave cylinder seals are worn!
Old 11-Mar-2006, 16:33   #4
Sounds like a little bit of clutch drag. Probably needs bleeding if its bad.
Old 11-Mar-2006, 16:44   #5
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
i'm with stu
it will stop spining a few seconds after you pull the lever
if it is still spinning then your clutch is dragging??
Old 11-Mar-2006, 17:01   #6
Originally posted by Glyn
i'm with stu
Have you been on something?
Once you pull the clutch lever in, it disengages the drive through the clutch, ie the pressure plate will be able to spin as long as you keep the lever pulled in!!! Just the same as sitting at the lights in gear with the clutch pulled in!! ffs
If it stops spinning a short while after initially spinning when you pulled the lever in, its the same as letting the lever out, releasing the pressure!
This must mean that there is a leak some where internally or externally!!
Old 11-Mar-2006, 17:12   #7
Glyn's Avatar
are we talking engine runing or not
cause im talking about the engine spining the presure plate the stoping after lever pulled in, e.g disingaging drive
not spining it by hand. why would you do that??
Old 11-Mar-2006, 17:34   #8
stu 748's Avatar
Yes thats what i ment too, if the engine is going and you pull the clutch lever in, after a few seconds the pressure plate stops rotating and the clutch drum keeps rotating with the engine. If not why bother having a clutch
Old 11-Mar-2006, 17:38   #9
Glyn's Avatar
well stu it's either us or them
but someone, as andy would say has been on something
Old 11-Mar-2006, 17:59   #10
stu 748's Avatar
Maybee Glyn some of the Ducati range came with Automatic gearboxes
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:17.
