Old 17-Mar-2006, 16:15
Mood: Come on spring!!!
Mounting brake fluid resevoir
Does anyone have any pics or tip on how to mount the front brake resevoir when using a radial M/C
Old 17-Mar-2006, 16:49
Rob B's Avatar
Rob B Rob B is offline
Mood: I'm so happyyyyyyyyyyyy
Depends what sort of clip ons you have. Earlier, I plugged the end of a clip on and threaded it to take a mounting.
or
now I use a tagged res' and mount it on the yoke.
Rgds, Rob
[Edited on 17-3-2006 by Rob B]
Old 20-Mar-2006, 20:50
Nigel Booker's Avatar
I'm having the same problem. P&H quoted me £64.00 for the bracket, reservoir and longer hose from the performance cat. Any pics or advice on relocating the brake fluid tank would be much appreciated.
Old 20-Mar-2006, 20:56
Harv748's Avatar
Harv748 Harv748 is offline
Just knock up some longer brackets either from strip metal (Halfords do some metal strip ready drilled for car stereos), or modify some other type of reservoir...and JHP sell the Brembo hose by the short length and the clips for pennies.
[Edited on 20-3-2006 by Harv748]
Old 20-Mar-2006, 23:27
Or take your time and make some proper ones..........
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:46.
