Old 20-Mar-2006, 23:29
Red-leader Red-leader is offline
Mood: wobbly !!!
Size of cylinder head nuts please
What size spanner for cylinder head nuts on a 900ss 91 please. Going to try and get rid of the oil leak this weekend.
Anyone have the Ducati special tool to borrow ?
Have a top man helping so not all bad.
Thanks Kev
Old 20-Mar-2006, 23:33
15mm. Can't help with the tool i'm afraid, but if you weld a socket mid way down a 15mm ring spanner, you can calculate the torque required at the torque wrench.
Old 20-Mar-2006, 23:37
Mood: wobbly !!!
Thankyou Mr Nelly
Its obviously not true what Dibble says about you
Please bear that in mind when you calculate his invoice.
Cheers Kev
Old 20-Mar-2006, 23:38
monstermob 998's Avatar
15mm ring spanner will do the job-- but you may have to grind the ring a tad thinner to get onto the nut--i used an old spanner and welded an old socket with half inch drive to take the torque wrench along the spanner shaft to make the special tool
Old 20-Mar-2006, 23:48
must learn to type faster- bit like my riding really
Old 20-Mar-2006, 23:57
Fiver's Avatar
Fiver Fiver is offline
Mood: gutted.
haha i just discovered the need for said tool this weekend.
Its surprising how much you have to grind the spanner down to get it to fit.
The need to buy myself a welder seems to grows with each bike i own...
Old 21-Mar-2006, 00:02
Mood: wobbly !!!
Think its a trip down the car shop for a cheap Draper ring spanner to grind down rather than the Snap On
Thanks for your help
Kev
Got to drop the engine out first though, oh what joy !
Old 21-Mar-2006, 00:33
I think I used a combination ring / open ended spanner and just happened to have a piece of box section the right size for the ring-end and getting my torque wrench on as well.
F
Old 21-Mar-2006, 18:12
Fiver's Avatar
Mood: gutted.
Do you think any of you could post a picture up of the spanner?
I'm gonna have a bash at making one up.
Thanks in advance
Cy
Old 21-Mar-2006, 18:57
The spanner is shown in the Haynes manual - its like a big 'C' shape.
Just had a look at the www.duc.nu site and the workshop manual on there - and the special tool is simply shown as a double ended ring spanner with a square hole tube built into the middle to allow a torque wrench to be fitted straight in.
F
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:25.
