Old 21-Mar-2006, 19:52   #1
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
Belts for my SL
How much and from where can I get a set of belts for my SL mailorder, Fancy doing them myself so after a price for the bits
Ian
Old 21-Mar-2006, 20:27   #2
chicken chicken is offline
chicken's Avatar
Nelly is the easy choice for all things Ducati for me but he's got limited storage space so he's not going to carry everything - would imagine he has a stock of belts though.
Alternatively, JHP (Ducati Coventry) is very quick and easy for oem bits.
Old 22-Mar-2006, 00:15   #3
phil_h phil_h is offline
phil_h's Avatar
john fallon at mdina italia is who supplied the belts in chi's FE
http://www.mdinaitalia.co.uk/
Old 22-Mar-2006, 14:42   #4
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
and they should be around 30 quid the pair.
Old 09-Apr-2006, 10:14   #5
Did the belts yesterday, must admit I didn`t expect the rear cam pulley to move like it did
Was a little tricky to hold it on the mark and fit the belt but did it in the end, all tensioned up using the allen key method shown here
http://www.buschandbusch.com/ducatisuite/home.html
Just going to recheck the tension this morning, but to anyone thinking of having a go, all I can say is go for it, it only took me an hour all in being very cautious
Ian
Old 09-Apr-2006, 16:45   #6
Zimbo Zimbo is offline
Zimbo's Avatar
Mood: fair to middling
david vs goliath
There's a simple trick to avoid fighting the spring pulling the cam pulley away from the timing mark, shredding the tips of your fingers - just back off the drive shaft pulley by the same amount. Once you've slipped the belt over them you move the crank pulley back to its timing mark and check the cam pulley is aligned to its mark. If not, move the crank back to release the tension and adjust the belt a notch. Repeat for second belt. The valves are both closed when you can spin the cam pullies easily.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:40.
