General Motorcycles only
Old 24-Mar-2006, 13:40   #1
Trig Trig is offline
Trig's Avatar
Mood: Fed up with DIY!
Touring
I want to do some 2 up touring. Does anyone know of any mod that can be done to the pillion pad that will make it more comfortable? I was thinking along the lines of a gel seat cover or similar.
Has anyone tried this? Will it fit a 999 pillion pad?
http://www.mandp.co.uk/productInfo.aspx?catRef=500687
Old 24-Mar-2006, 14:28   #2
Founder Member
Paul James's Avatar
Well worth fitting some non slip mat to the rear seat, makes a real difference to the passengers stability. We use it even on the ST and tend to rack up a few miles on some of our trips.
You can get a big sheet from places like Halfords.
Old 24-Mar-2006, 16:56   #3
Trig's Avatar
Thanks Paul. I agree the non slip mat deffinitely helps and my wife has used it very sucessfully on the 748 I used to own. But with distances of around 300 miles the pillion perch on the 999 isn't the best place to be so I want to make her as comfortable as possible
I figured a gel seat cover that might also increase the seat to foot rest distance, if only slightly, would be the answer.
I don't want to order this M & P version and/or others only to have to send them back again because they don't fit, the restraining buckles scratch the body work, etc.
Old 24-Mar-2006, 18:22   #4
david.hicks's Avatar
I have a better solution - how about one of these
Old 24-Mar-2006, 18:32   #5
Trig's Avatar
I am not that desperate to make her comfortable:P
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:31.
