Old 26-Mar-2006, 23:28
monstermob 998's Avatar
whats best??
whats best lubricant for electrical terminals??-- the starter motor connection and starter relay specifically, on the carby SS , although both are covered by little rubber boots to protect them the boots are fitted upside down and are not self draining- they fill up with water quite easily! and rust the terminals-- would a smear of vaseline as you would on the battery terminals be sufficent- or is there a more specific electrical grease/protector i could use? i know i should'nt ride in sub zero temparatures with salt on the roads but it was the voices made me do it
p.s am now fitting my spare starter motor
Old 26-Mar-2006, 23:33
Darren27 Darren27 is offline
Mood: Offshore
Molycote 111 or DC4 is a good bet (if you can find it), failing that
try RS electrical silicone grease.
Old 26-Mar-2006, 23:41
thanks darren - would i get the RS grease from electricians supplies or order thru RS?
Old 26-Mar-2006, 23:52
Carbon749's Avatar
Mood: I own a flame thrower
Try one of these ...
http://www.maplin.co.uk/Search.aspx?...26m3&source=15
Old 27-Mar-2006, 03:41
edwyun edwyun is offline
for the starter motor rubber boot, poke a hole on the bottom of the rubber boot so that any moisture can drain out (ie: need a somewhat decent sized hole to avoid capillary action).
also put some dielectric grease or similar inside at the connection.
Old 27-Mar-2006, 11:34
Mood: Offshore
Yes RS components ,
Silicone Grease
stock number 494-124
£3.83 for a large toothpaste sized tube.
Old 27-Mar-2006, 11:57
Even good old Halfords do a battery terminal connection spray at a reasonable price - comes out as a funny green foam - but at least its easy to see where its been sprayed !!!
Frank
Old 27-Mar-2006, 13:46
thanks for sharing your knowledge guys- have gone for the RS silicon grease- i guess you can use this on any electrical connection and did think of adding a drain hole !!!
Old 27-Mar-2006, 13:59
Mood: Offshore
The RS should be good on any electrics, just be careful as it is not a lubricant. Its not as bad as the DC4 which can wear out a new grease gun with one fill, but is good at keeping the water out.
Old 27-Mar-2006, 14:12
Derek's Avatar
Derek Derek is offline
Bikes: ST4s ABS
Waxoyl is also ok for battery terminals and connections to the starter and solenoid.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:12.
