Old 31-Mar-2006, 20:45   #1
loverobot's Avatar
Front sprocket
stupid question maybe but I have removed the to sprocket retaining bolts and the retaining plate and the sprocket wont budge off the shaft
is there anythin ia m missing here or is brute force required
Old 31-Mar-2006, 20:57   #2
moto748 moto748 is offline
It should just slide off. I've never had a problem getting the sprocket off, except that ot quite a tight squeeze to clear the chain.
I'd dribble some 3-in-1 oil or suchlike into the splines and try gently tapping it with a hide mallet or a big screwdriver handle.
Old 31-Mar-2006, 21:05   #3
loverobot's Avatar
nope the chain is off and i expected the sprocket to do just as you say ie slide off
Old 31-Mar-2006, 21:43   #4
JACKO748S JACKO748S is offline
JACKO748S's Avatar
Yep, should just slide off mate.
Just be very careful when you do the bolts back up again when the new sprocket is on - they are like chocolate....I know this from experience/ineptitude.
"Ooooh, I'll just nip it up a little bit mo......ah, f**k!......lol....
Old 31-Mar-2006, 21:45   #5
loverobot's Avatar
so what would you do if it didnt just slide off like mine?!
Old 31-Mar-2006, 21:48   #6
JACKO748S's Avatar
wd40?
Old 31-Mar-2006, 21:56   #7
loverobot's Avatar
my first thought but doesnt seem to have helped
Old 31-Mar-2006, 22:01   #8
JACKO748S's Avatar
Is there much in the way of corrosion etc. there?
If there is it might need to soak in overnight mate, followed by what moto suggested - a bit of tapping to "crack" the crap that's built up in the area.
Sorry can't help anymore than this fella.
Jacko.
[Edited on 31-3-2006 by JACKO748S]
Old 31-Mar-2006, 22:05   #9
loverobot's Avatar
will soak it and hope!
Old 31-Mar-2006, 22:08   #10
JACKO748S's Avatar
Yeah, go have a beer and try again in the morning!
Good luck with it.
Jacko (off to work in 45 minutes )
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:49.
