Old 03-Apr-2006, 14:16   #1
weeksy2 weeksy2 is offline
Headlight VERY dim on standard dipped beam.
But the bulb looks OK....
any thoughts guys ?
Old 03-Apr-2006, 14:35   #2
Dibble
yep, they all do that Sir .... buy a head torch ...
Old 03-Apr-2006, 17:05   #3
nooooo i mean seriously dim... he didn't want to pass it on the MOT.... it was that bad.
Old 03-Apr-2006, 17:45   #4
Stinkwheel Stinkwheel is offline
Have you checked the connections on the bulb and the plug for corrosion? Sounds like high resistance... Next thing to do would be to check for 12 volts at the plug. If you get 12 volts its likely to be a dodgy bulb, if you get less then keep working backwards until you find the source of your problem...
Good luck, hope this helps!
Stinkwheel.
Old 03-Apr-2006, 17:47   #5
Not really checked anything yet fella... had to ride it this weekend instead
Course it helps mate... can never have too many words of wisdom.
Old 03-Apr-2006, 18:10   #6
Harv748 Harv748 is offline
Harv748's Avatar
Just check the bulb mate...it sounds like it is justing showing as the park light...and not the proper main beam (not to be confused with the high beam!). I reckon the filament has gone.
Flick the light switch one position to parking light, and have a look at the brightness, then up the switch to main beam and see it it increases in brightness in any way.
If not, then I think its just the filament for the main beam gone. If it does a little, but not enough, then perhaps the problem lies elsewhere as mentioned before.
[Edited on 3-4-2006 by Harv748]
Old 04-Apr-2006, 09:44   #7
thanks Harv... that will be my task for this afternoon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:01.
