Old 09-Apr-2006, 15:09   #1
flanagaj flanagaj is offline
Stuck trying to fit a JH Performance air filter :-(
For some strange reason I thought rather than replace my 748 air filters with the same type I'd go for a performance air filter. This thing sits in the main air box under the tank and is a great hunk of foam with two holes cut into it that sit over the bellows ?. I managed to get it fitted, but I was wondering whether anyone else has heard of this brand. The filter was also dry where as some come coated in a solution to help catch the dust.
Old 09-Apr-2006, 15:43   #2
Dibble
yes, its from John Hackett the Ducati Performance specialist, go look at www.ducaticoventry.com where you'll find some JHP info ...
If you are watching BSB at the mo, he is the man that runs JHP that builds Lavillas and Haslams bikes ..
I also have one, its fine. Enjoy.
Old 09-Apr-2006, 16:12   #3
Gaz 748's Avatar
I had a ITG filter ( same thing ) it should be sprayed with filter oil, i got mine with the filter from Baines.
Old 09-Apr-2006, 17:59   #4
Thanks for that. I got it fitted in the end.
Old 10-Apr-2006, 10:12   #5
Ray Ray is offline
Ray's Avatar
Depends on the model of 748, if its an R I don't believe you can use the type of filter you mention.
Ray
Old 10-Apr-2006, 11:02   #6
rcgbob44's Avatar
Flanagaj !!!
You have the "old" type of filter, these have been superceded by the twin K&N type,
I think there were problems of these foam filter burning if there was a back fire in the air box.
What model 748 have you got?
Old 10-Apr-2006, 21:43   #7
y2k 748 bp
Old 11-Apr-2006, 04:31   #8
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello flanagaj
I fiited an ITG filter, and found it easier if you unscrew the rear belmouth, fit the difficult front one first, then refit the belmouth.
been using these filters for about four years.
regards
TopiToo
Old 11-Apr-2006, 09:28   #9
Are you sure about the Dibbs? Im impressed if he does, i think gse do their own stuff.
that said, you wont go far wrong with jhp regardless!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:13.
