Old 04-May-2006, 15:59   #1
B19PSK B19PSK is offline
Bikes: 998S and MTS1200S
B19PSK's Avatar
Mood: Growing old disgracefully, DSC member 2387
Front cog
To change or not to change, that is the question.
If yes, to what and from where do I buy,
Paul of London Heathrow
Old 04-May-2006, 16:09   #2
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
Yep - well worth doing - try this lot;
http://www.bandcexpress.co.uk/cgi-bi...l?cat=SPR-ROAD
Tim
Old 04-May-2006, 16:16   #3
DSC Member final_edition final_edition is offline
final_edition's Avatar
Mood: Having some tinnies and a barbie
I believe that Amsterdam have lots of spare cogs from thieir windmills.
Old 04-May-2006, 16:23   #4
B19PSK's Avatar
14 tooth?
Will this make the speedo inaccurate?
Old 04-May-2006, 16:40   #5
14 tooth?
no speedo runs off of the front wheel...............
I would go up on the rear sprocket rather than down on the front....... less stress on the chain with a more powerful bike than a 748 that has 14 as std...........and you could have a bling sprocket carrier.......
Old 04-May-2006, 16:53   #6
Totto Totto is offline
But if you go up on the rear you will shorten the wheelbase , i run a 14 tooth on my 998bp althought the S is up a few brake hp
You could spend the money and put a Renthal carrier on the rear change the chain & sprockets at the same time that way you can keep the wheelbase std or go longer
Old 04-May-2006, 20:56   #7
I have and would allways go for a longer chain to keep the eccentric at the bottom and even 5 o clock as you look at it sprocket side!
besides if you fitting new sprockets you really out to fit a new chain anyway!
Old 05-May-2006, 03:26   #8
DEMON DEMON is offline
Bikes: 996 sps foggy, 2001 r6, 1098S, s1000rr, Panigale 1199S
DEMON's Avatar
Mood: on the back wheel !!
14 tooth?
why will there be more stress on the cog ?
let me make you think a little... before I answer this one
the diameter of the cog is smaller ?
It is subjected to the same power ?
The chain will transmit more or less power ?
Old 05-May-2006, 09:50   #9
B19PSK's Avatar
Rather than power think pressure, clearly for a given chain size a smaller number of teeth mean a smaller diameter, means a larger pressure on each tooth! IMHO
Old 05-May-2006, 14:52   #10
See Tales of the Front Sprocket here:
http://ducatisportingclub.com/xmb/vi...=9386#pid78060
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:22.
