General Motorcycles only
Old 10-May-2006, 10:31
Paul James's Avatar
Founder Member
Originally posted by antonye
Originally posted by andyb
God it must be exciting at work...................
Haven't you got some paperwork to fill out?
Or some old dears with no lights on their bikes to go and nick
Old 10-May-2006, 10:33
Paul James's Avatar
Founder Member
You may need to set the cell formatting on the range once you've copied the formulas over. Excel can be funny like this sometimes as it constantly tries to do a "best guess" about the formatting of a cell when the contents change. It's a right pita for us developers!
Spot on again; it tried to set the format to Greek for some of the cells !! All sorted now so I'm going to risk merging the database to my labels and inspection reports.
Old 10-May-2006, 10:37
They make us do it in excel now.................any help?
Old 10-May-2006, 10:44
Paul James's Avatar
Founder Member
Probably not cos the zeros keep getting added at the other end when it comes to speeding fines :P:P
Old 10-May-2006, 10:46
Paul James's Avatar
Founder Member
Spoke too soon saved the database then tried to merge and the leading zeroes dissapeared. Checked the format again and the whole column has reformatted to Greek. Arghhhhh!!! Bl**dy Microsoft !!!!*"+***
Old 10-May-2006, 13:13
moto748 moto748 is offline
Only consolation is, it's still a much better piece of software than Word!
Old 10-May-2006, 13:17
guest1 guest1 is offline
Paul, you need to include text in your formula and copy that formula to all of your cells.
e.g. in cell C8 I have entered 7425
I have formatted cell C8 to 6 0's (custom format)
in cell C9 I have entered a number 12 (no custom formatting)
in cell C10 I would normally have entered =C8*C9 and seen a result of 89100
Custom formatting cell C10 could produce 089100 with your leading zero's, but you could also use the following formula instead:
=TEXT(C9*C8,"000000")
Unfortunately that does turn the cell into text but you can still use that text in another formula e.g. =C10*1 = 89100
Merging into Word you will need to alter the field formatting withinthe word document - use F9 to reveal field codes
  #18
Old 10-May-2006, 14:06
Paul James's Avatar
Founder Member
Thanks Alan, interesting option but what I'm trying to do is make up a simple column (which I can do if there are no leading zeros) so that I have a production date say 030406, with 01 to 99 behind that to give me up to 99 batches per day. Then by using the first entry in the column say 03040601 I can put a simple formula in the next row down =that cell+1. This when copied and pasted into the required number of cells gives a simple chronological record, when the date changes by a day it's a simple matter of changing one cell and carrying on copying the +1 formula. Once I've saved the excel sheet I can use the info in all sorts of ways by merging to word documents. Labels, production test records, delivery notes etc.
Just tried amending to suit my application and by formatting all the cells as text it seems to be working.
Thanks again to all for the advice
[Edited on 10-5-2006 by Paul James]
  #19
Old 10-May-2006, 18:34
Paul, use of formatting can extend to dates as text.
I'll speak in excel cell terms
a table with three columns, starting at C5.
Cell C5 - enter the date, format the cell as custom with ddmmyy
C5 should now say 030406
Cell D5 - enter the number 1, format the cell as custom with 00
Cell D5 should now say 01
Formatting of these two cells is pretty irrelevant really because our formatting will take place in the result cell E5
Cell E5 - enter the following formula: =TEXT(C5,"ddmmyy")&TEXT(D5,"00")
Cell E5 should now contain the text 03040601
Should now be a case of just copying the relevant rows down as far as you need and adding your own formulas.
e,g,
Cells C6 to C100 enter formula =$C$5
Cell D6 enter = D5+1
And just drag down the E cell formulas.
If you get stuck send us a u2u
  #20
Old 11-May-2006, 14:24
Paul James's Avatar
Founder Member
e,g,
Seems to be all working now so fingers crossed and thanks again for all the info, much appreciated.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:56.
