Old 10-May-2006, 12:16   #1
weeksy2 weeksy2 is offline
Brake upgrades and whether they are worth it ?
Well today was the first ride out on the new Brembo P34's....
Didn't notice an ounce of difference.... (apart from being a lot prettier ).
Bite was the same, feel was the same...
Don't know if it would feeling improved on trackday/raceday or not at this stage... but for normal road riding, i couldn't notice a thing over the standard 2 pad calipers.
Old 10-May-2006, 12:21   #2
What master cylinder are you using? the original one?
Old 10-May-2006, 12:27   #3
Yep, but this isn't a MC debate... it's a caliper debate ?
unless we're thinking that the P34's with a Brembo MC would work better than P4's with a Brembo MC ?
I'm 100% convinced fitting a Brembo MC would improve things.... but surely equally on both ?
Old 10-May-2006, 12:31   #4
Oh how blind........its a size thing! if youve got your std m/cylinder that was designed to move enough fluid to actuate you std 2 pot callipers..........then asking it to work with 4 pot ones........and expect an improvement is pushing it to say the least.
Obviously your the educated one (picking me up on my spelling) do the maths!
Old 10-May-2006, 12:31   #5
What and you have bedded the already used sintered pads from different discs into your original used discs already.
Old 10-May-2006, 12:35   #6
Dunno really mate to be honest.... they are still obviously fairly 'new' in there... did a 35 mile ride up to now on them... but not a huge amount of braking.... but 5-6 decent stops....
Could well be a bedding in type scenario yeah.
Old 10-May-2006, 12:36   #7
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Ummm...isn't the std master cylinder on a 916 a Brembo and aren't the standard calipers 4-potters? If so, then the std master cylinder should be fine imo. FWIW I have never noticed a deficiency in the std Goldline calipers for road or track use. I would recommend better fluid, better levers (with less slack and wobble in them), pads (Performance Friction), discs (cast-iron floaters) and brake lines for track use though.
Calipers would be the last thing I changed.
Old 10-May-2006, 12:36   #8
i was under the impression the MC on the 748R etc (P34's as standard) was the same as mine now ?
Is the R MC better then ?
Old 10-May-2006, 12:37   #9
prettier though TW much prettier
Old 10-May-2006, 12:43   #10
Rated by Simon Knowlson as one of the best upgrades he carried out to his 748RS over the winter and that was before he had taken a win and 2nd place in the NG F600 championships on a 6 year old bike.
I find the P34s on my 998 Hybrid have a lot more bite than the P4s on my 996 and they both use identical Brembo Radial M/Cyls
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:02.
