  #31
Old 10-May-2006, 13:28
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Originally posted by andyb
isnt when to brake and when to get on the throttle race craft then?
As is big balls and staying on (not directed at TP by the way).
  #32
Old 10-May-2006, 13:33
So after visiting the brembo fairy.......note- visit the big balls fairy too!!
  #33
Old 10-May-2006, 14:06
Nope - that's not racecraft - that's operating the motorcycle.
  #34
Old 10-May-2006, 14:14
dickieducati's Avatar
  #35
Old 10-May-2006, 14:56
weeksy2 weeksy2 is offline
Ohlins was sold through lack of funds.... Showa is staying on till i can afford it.
  #36
Old 10-May-2006, 15:33
Originally posted by dickieducati
Originally posted by Jools
BTW: I disagree with Dickie, I find that if I've got total confidence on the brakes I can use a much, much deeper braking marker and keep the throttle pinned for longer
you will make up time by braking later but in comparison to getting on the throttle early and carrying it through a fast section it is tiny by comparison. we are talking tenths of seconds compared to seconds.
Exactly.
Braking very late and hard will help you pass people, but is likely to actually have a negative impact on your laptime as when you're braking really hard your field of vision narrows and you are less likely to turn your attention to the apex etc early enough and therefore lose some corner entry speed. Not to mention the fact that you're probably gripping the bars in a vice-like death grip and not allowing the front suspension to do its job properly.
This is of course unless you have plenty of experience doing this and can overcome your subconscious survival reactions.
This year I've raced with the 4 pad calipers and the 2 pad calipers - the 4 pads have more power for sure.
Blimey...anyone would think you're a CSS instructor or something
Actually, what I have managed to do quite well on road and track is put the CSS techniques into practise when I'm on the brakes, and I try and brake smoothly but firmly, even very hard, all the way up to my 'brakes off' marker which is usually just a tad before my turn in point.
I always use two fingers to brake and I can blip the throttle on downchanges (without changing braking pressure) while braking as well, so slowing the bike and getting into the right cog for the drive through the bend is usually a very smooth process for me. I've worked hard at gripping the tank with my knees so I usually take all the braking 'G' using my thighs and lower back and I only need to hold the bars lightly.
As soon as I'm off the brakes I wait a split second to lett the suspension settle and wind the throttle on as soon as I tip it in (not sure how you can get on it any earlier) and wind it on as progressively as I can for any given track condition.
I don't trail brake - don't trust myself feathering the brake while cranked over - I get all my braking and gear shifting done in a straight line.
So what I try to do is brake hard and late (without rushing the corner) AND get on the gas early. I'm probably dog slow compared to racers but I think I've got the technique about right (never perfect, there's always room for improvement) it's just the size of me nads that slows me down.
  #37
Old 10-May-2006, 16:04
So outbraking someone isnt race craft?..........best tell bayliss that about monza then...............first bend after long straight.
operating the motorcycle is pulling the lever!!.........trust me! ill show you my qualifications if you show me yours...........
  #38
Old 10-May-2006, 18:54
DC's Avatar
DC DC is offline
Mood: Double 9, Single 6.
Got P34 calipers on my 748-996sps hybrid with radial master cylinder and it transformed the front end braking.
True one finger braking.
DC
  #39
Old 10-May-2006, 18:57
Simply having a braking marker isn't racecraft - choosing to push it back to complete an overtaking move is. Planning overtakes, race strategy etc - racecraft. Turning the bike or having a braking marker - just lapping a circuit.
See the difference yet?
  #40
Old 10-May-2006, 19:00
That's excellent - you're overcoming the survival reactions consciously and reaping the benefits. The school was worth it then?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:54.
