Old 10-May-2006, 18:23
flanagaj flanagaj is offline
Symptons of worn clutch basket
Can anyone tell me what the symptons of a worn clutch basket are ?
Thanks
Old 10-May-2006, 18:26
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
noise
yep more than normal
only quivk job to pop off the pressure plate and have a look
Old 10-May-2006, 18:29
and you might find the clutch take up is a bit clunky as the plates ride over the grooves they've worn in the basket...but as yer man says, tis only a few bolts to take the covers off and have a gander
Old 10-May-2006, 18:47
Originally posted by Glyn
noise
If there are any grooves does it mean it needs replacing ?
Old 10-May-2006, 18:58
Fordie's Avatar
Fordie Fordie is offline
Regional Organiser - BHCN
Mood: Raring to Ride
Oh yes, there will be grooves,depending on whether the clutch plates have embedded grooves into the basket or both.On inspection you will see both the plates and basket and see how much wear has taken place. Plates dont last forever unless your'e a polishing merchant,one that does'nt get out and ride it, any thing from 12,000 16,000 mile depending how much stick you give it. 4D
Old 10-May-2006, 19:02
Is it a job that is easy to do yourself ?
Old 10-May-2006, 19:03
zhed44's Avatar
zhed44 zhed44 is offline
Mood: YELLOW!!!
mine only lasted 3000 on the bandit the duke's went at 12000, but only 2K of those were mine
[Edited on 10-5-2006 by zhed44]
Old 10-May-2006, 19:11
deej's Avatar
deej deej is offline
wont as long if its a slipper clutch
Old 10-May-2006, 19:16
Fordie's Avatar
easy peasy, cover plate of, undo the spring/cup bolts(allen key) that will free the pressure plate,the clutch push rod may want to come out with it, thats about 12" long in old money.It should really be free,it sits in a bearing in the pressure plate. take out a few plates to see the WAT (wear and tear) assess and replace. 1/2 hour job . 4D
Old 10-May-2006, 19:18
zhed44's Avatar
Mood: YELLOW!!!
is he talking about changing the plates or the basket?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:54.
