Old 10-May-2006, 20:24   #11
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
Originally posted by zhed44
Originally posted by Fordie
easy peasy, cover plate of, undo the spring/cup bolts(allen key) that will free the pressure plate,the clutch push rod may want to come out with it, thats about 12" long in old money.It should really be free,it sits in a bearing in the pressure plate. take out a few plates to see the WAT (wear and tear) assess and replace. 1/2 hour job . 4D
is he talking about changing the plates or the basket?
about assessing the job
Old 10-May-2006, 20:29   #12
who Fordie...............
If you need/want to change the drum you need a big socket, torque wrench and a clutch holding tool.
Old 10-May-2006, 20:34   #13
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Better still AndyB, you need NELLY Actually changing the basket is a little more involved and special tools are reguired,as you say not a DIY job really. 4D
Old 10-May-2006, 20:45   #14
Glyn's Avatar
its not hard pete
i managed it
as andy says you do need a cluth holding tool also a bloody big torqe wrench
to just assess the condition though is as you say a very easy job
Old 10-May-2006, 20:48   #15
Its not actually that big a job, even with a slipper. your right though if in doubt get it done by someone that knows........and has the kit!
Old 10-May-2006, 20:49   #16
Glyn's Avatar
i nearly popped a testie trying to do that damn nut up
Old 10-May-2006, 20:51   #17
The service limit on the basket is a lot less than the amount of wear that actually starts to cause a problem if that makes sense!!
In other words you are supposed to change it but in reallity it will keep on working for ages.
Symptoms are jerky clucth release as the plates slide over the notches in the basket fingers. You can dress them out with a file though. This will result in more noise unless you are running ST4S alloy clutch plates.
Old 10-May-2006, 20:59   #18
i could of leant you the tool.tool.... You in tomorrow?
Old 14-May-2006, 10:39   #19
flanagaj flanagaj is offline
Looks as though the plates and basket have worn. In the Haynes Manual it says that if the engine is in the frame you can just put it in gear, press the back brake on hard and remove the clutch without any special tools.
Is this correct ?
PS - Should I go standard basket and plates or buy a slipper ?
Either way can anyone drop me details as to where the best place to buy is ?
Thanks
Old 14-May-2006, 11:18   #20
Really depends on how good your back brake is and if you have someone to help you. I think the big nut is something like 180N/m. Some people put bits of wood through the back wheel. If you've got an old set of plates, some half inch bar and a welder you can make a clutch holding tool.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:35.
