Old 11-May-2006, 22:09   #1
Guy C Guy C is offline
Mood: I ordered a Cheese Burger
Back wheel knock
Gang.
Sometimes when I pull away or change into second I get a bit of a knock/clunk from the back end, can feel it too. Pretty certain its in the back wheel.
Tonight laying under the bike in case anything obvious was dropping off I put the back brake on and tried moving the wheel. Seems to be some movement in the caliper carrier and I can make it clunk/knock by rocking the wheel.
Any ideas? Should it do that? (All nuts and bolts nipped up nicely)
Old 12-May-2006, 12:29   #2
Bikes: 748R, ZXR 400
raykay748R's Avatar
Check cush drives.
Old 12-May-2006, 12:49   #3
If you're in Nottingham a quick trip to Cornerspeed in would tell you what was what.
Old 12-May-2006, 14:39   #4
khushy khushy is offline
khushy's Avatar
the carrier movement is normal - they all do that BUT the fact that you can hear it above all the din the bike makes is not normal.
I would say that you have rear caliper problems - its sticking - once "unstuck" there should be no noise - if you can - try removing the rear brake COMPLETELY FROM THE BIKE and see if the noise is still there.
Caliper needs cleaning/servicing/binning etc
Khushy
[Edited on 12-5-2006 by khushy]
Old 15-May-2006, 17:57   #5
Thanks guys.
Have had the caliper off and cleaned and re greased it (in the right places) working fine but the noise is still there.
Cush drives next...................................
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:48.
