Old 13-May-2006, 20:29   #1
david.hicks's Avatar
SPS Mono to Biposto conversion
I assume I will need to change to a Biposto subframe. Will it just bolt straight on?
Old 13-May-2006, 20:32   #2
why would you want to
you'll only spoil it.....
dont know the answer tho.....
Old 13-May-2006, 20:32   #3
Carbon749's Avatar
Mood: I own a flame thrower
To convert a Mono to BP you will need the steel subframe as it's designed to take the weight of 2 plus it has the lugs for rear foot pegs.
Being as the mono seat fits the BP subframe without modification I would assume that the seat units and subframes are all interchangable and will fit the frame OK.
[Edited on 13-5-2006 by Carbon749]
Old 13-May-2006, 20:34   #4
think the only issue may be fitment of the p-thingy which holds your cpu brain
Old 13-May-2006, 20:39   #5
'coz the Mrs finds it a bit bloody uncomfortable as it is
Old 13-May-2006, 21:08   #6
ducv2 ducv2 is offline
It will bolt straight on, but you will need to make brackets up for the cpu.
Old 15-May-2006, 10:38   #7
You know, on reflection I think you are right. I think I'm gonna do this instead
[Edited on 15-5-2006 by david.hicks]
Old 15-May-2006, 12:28   #8
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Yuk.
Old 15-May-2006, 17:59   #9
Originally posted by chass
Yuk.
What doe you mean 'Yuk'
That sidecar is 100% carbon fibre I'll have you know
Old 16-May-2006, 07:14   #10
Is'nt there some issue with SPS wheels not being designed to take the weight of two people?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:27.
