Old 22-May-2006, 21:47   #11
whats the torque number on that brogins?
Old 22-May-2006, 22:02   #12
Bionicle Bionicle is offline
Bionicle's Avatar
04 999R pc111 54mm full system
Old 23-May-2006, 19:34   #13
Simon Reed's Avatar
Mood: Cool as **** !
Crank to wheel loss is 15%,not 8!,work back from that !
[Edited on 23-5-2006 by Simon Reed]
Old 23-May-2006, 21:27   #14
Felix Felix is offline
That wants racing, mate, that does!
Old 24-May-2006, 10:03   #15
Bionicle's Avatar
Wish i was young enough and good enough
Old 26-May-2006, 00:35   #16
Brogins Brogins is offline
Brogins's Avatar
Mood: PENSO POSITIVO....SEMPRE!!
std dyno value
Hi Brad, 78.5... dunno the difference from the std...
On power I think we go from 123 std to 131 on a 05 model with the system, the filters ( the filters I guess zero gain) and the PCIII.
The std 03/04 model (not S) was 118.5.
Old 26-May-2006, 14:48   #17
couchcommando's Avatar
Mood: ooooh
It's not that simple is it tho ?
A bike with 100 hp loses 15hp thro the transmission yet the same bike tuned with 140hp loses 21hp even tho the transmission is exactly the same ?
All you can get is educated guesses at crank horsepower. I don't know how the dyno shops that give sheets out with crank horsepower work it out when the reading is taken from the wheel ?
In fact I see no reason why they would estimate a crank reading other than trying to impress the owner with bigger figures.
Also comparing readings from different dyno's on different days is no good. All that actually matters is before and after on your own bike.
My TLR race bike had 139 at the rear wheel on one dyno and 134 on another with no changes to the bike.
Old 26-May-2006, 16:11   #18
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Yep. CC is spot on. On one dyno on one day my 800ss roadbike was giving 80bhp. On another dyno on a different day it was giving 76-77bhp.
Old 26-May-2006, 23:53   #19
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
dyno charts..
Pre big exhaust .. so standard "open" Ecu and exhaust
134 ps at the rear wheel
still waiting for the next printout
Old 01-Jun-2006, 21:26   #20
nathanhu's Avatar
Mood: head down
next map was 57mm system without power commander..
looks a little messy, but pulls much stronger out of the corners but the flat spot is massive...
File Type: jpg dyno run 2 57mm system- no power commandeminir.JPG (53.7 KB, 11 views)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:29.
