Old 23-May-2006, 17:16
yeti's Avatar
yeti yeti is offline
Originally posted by JPM
I'm hoping Yeti has taken the idea on board and will be knocking one out (pardon the pun) shortly
Hum, might just have to think about that one.
Not that Felix will be gettin one cos he still owes me a workshop manual!!!!!!
Old 23-May-2006, 17:20
make it harder to start too if you up the idle...have you tried starting from cold with an open throttle or fast idle on
Old 23-May-2006, 17:23
yeti's Avatar
I've been running fast idel on the beast for a while and she always fires up first kick. Pretty certain the TPS will spot this and adjust the brain accordingly.
Old 23-May-2006, 17:26
my sps has never been able to start with the idle pressed in, the engine doesnt turn over quick enough even with a fully charge battery
its a matter of catching it when it sounds like its going to start....also talking to MR today he said if I up the idle it may may it a bit more difficult to get going
Old 23-May-2006, 17:28
yeti's Avatar
Hm, tough one that, looks like I gonna have to design and build an adjustable one that can be brought into play when on the move.
[Edited on 23-5-2006 by yeti]
Old 23-May-2006, 17:36
khushy's Avatar
khushy khushy is offline
an idea for ya . . .
having fitted longer bars to my 999s - I had to remove the "choke" (LOL) cable as it would NOT now reach where I moved the LH switchgear to.
Never use it anyway and all it does is pull the throttles slightly when activated.
Anyway, I have it cabletied underneath the ignition barrel for now - was thinking of buying a braze on gear selector off a push bike and attaching the cable to this so that if I needed to I could still pull the chokey!!!
The braze on lever (well its band on actually) fits exactly around the frame so I can mount it anywhere within reason - that might just do the job for you!
Khushy
[Edited on 23-5-2006 by khushy]
Old 23-May-2006, 18:31
Felix Felix is offline
If you're suggesting a trade, I am game!
  #18
Old 23-May-2006, 19:03
iang's Avatar
iang iang is offline
I was told that if you look carefully at the side of the airbox there is a rubber grommet, if you remove this and put a long screwdriver in you can adjust the idle screw.
I have looked in the past and there is a rubber grommet but I have never looked to see if it works ?
  #19
Old 23-May-2006, 19:26
Simon Reed's Avatar
Mood: Cool as **** !
So,whats the benefit of this "fast idle ",then,when,on track,eh ????
  #20
Old 23-May-2006, 21:20
It makes going aroung the slow hairpins smoother, as you can ride round on closed throttle.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:41.
